Author Topic: Need a Qjet Guru  (Read 11109 times)
Offline slammed79
  • Thou shalt not drive stock
Need a Qjet Guru
« on: May 10, 2013, 07:34:21 pm »
Hiya Folks.
    A few weeks back I rebuilt my quadrajet, even though it was "rebuilt" last year. The dude (who was a friend of mine) who rebuilt the carb, essentially did an exterior clean, and maybe adjusted the float. The carb started leaking between the baseplate and the bowl assembly. When I broke the carb open, it looked like it hadn't been touched in 10 years.
I bought a rebuild kit, new float and a choke pull-off from Napa, cleaned everything and put it back together.
Before the rebuild, I was getting roughly 11 in town. This is down from the 14 or so I was getting last year. I did add the steel 20"s and I discovered a fair amount of vacuum leaks caused by dried out hoses. Now, after the rebuild, I'm only pulling 8.5.
I must of messed up somewhere. Can anyone give me an idea of where to start looking?
Praise the lowered
Offline 454Man
  • Why Race?
Re: Need a Qjet Guru
« Reply #1 on: May 10, 2013, 08:07:46 pm »
Pics or carb #s would help a little. Did you adjust the Float?
« Reply #2 on: May 10, 2013, 08:13:06 pm »
Assuming you didn't switch to the 20s at the same time you did the O/H and the timing is correct:
  • wrong float, float level incorrect, or needle valve improperly 'hooked' to float
  • power valve piston stuck, or rods not inserted into primary jets, or rods missing
  • wrong bowl gasket installed
  • warped bowl cover
  • pull(s)/choke not correctly adjusted, or choke not opening
  • leaking fuel well plugs or accelerator passage lead plug
  • idle mixture screws set too rich
  • air bleeds plugged
  • vacuum hoses improperly routed/connected, or
  • runs so well, your using all that extra power!   :o
« Last Edit: May 10, 2013, 08:15:06 pm by bd »
Offline Fairlane514
« Reply #3 on: May 10, 2013, 11:15:31 pm »
The primary throttle shaft is usually worn and loose and can cause a small vacuum leak.
Offline slammed79
« Reply #4 on: May 11, 2013, 02:02:26 pm »
wrong float, float level incorrect, or needle valve improperly 'hooked' to float.
 I bought the float at the same time I bought the kit, and the clerk at Napa went off my carb number for the parts, so I'd hope I got the right stuff. I did set the float level, but that was the only part I was unsure of when I did the job. The carb # is 17058212. The stupid little clip on the needle valve was hooked on as I found it before.
The metering rods are there and were set back into the jets. This was a bit of a pita after a couple adult beverages, but I got it done. Was moving well on reassembly.
I matched this up with the existing one. Thats not to say is it is in fact the correct piece, but it did seem to seat right, and looked correct.
warped bowl cover
Would this cause a massive drop in fuel mpg? I'm sure it'd cause a vacuum leak, but it seems like I got all those taken care of with the new hoses.
It seems to be doing its job, but it is late spring in AZ, so who knows if it is in fact working
What could cause that? I did blow out all the little nooks and crannys I saw before I reassembled.
I thought the same, and turned them back in to snug, then backed out two turns. They went in two and a half before they hit snug.
air bleeds plugged
Misc debris in there?
pics attached of the vacuum hoses , or
She's running real nice, just drinking gas like its a buck a gallon. lol
Pics
The egr is running into the port on the side, the pulloff to the lower, and that upper hose is going to the vacuum advance.
Praise the lowered
Offline rich weyand
« Reply #5 on: May 11, 2013, 02:19:37 pm »
Vacuum advance is connected incorrectly.  You don't want it on "ported" vacuum, you want it on manifold vacuum.  Switch the vacuum advance to the lower vacuum port.  I'm not even sure looking at it that that is a vacuum port that you have it connected to.
See this pic.  You want a "non-ported" vacuum source for the advance.
http://www.gtoforum.com/attachments/f50/9784d1293232179-who-has-best-book-help-me-convert-quadrajet-img_20101224_163810.jpg
« Reply #6 on: May 11, 2013, 03:16:59 pm »
wrong float, float level incorrect, or needle valve improperly 'hooked' to float...
Issues with the float/needle valve can cause it to run rich.  If the new and old floats appear the same, no worries.  If you're not sure of the float adjustment, however, recheck it!  High float setting can cause early tip-in of the main fuel nozzles and increase fuel consumption.  This is probably the most likely scenario.  Instructions and a gauge should have come with your kit.  The needle shouldn't be hooked into one of the 'holes' on the float, because that can interfere with needle valve function, causing it to hang open.
warped bowl cover...
Warped bowl covers, although common, would more likely result in drivability issues than excess fuel consumption.
pull(s)/choke not correctly adjusted, or choke not opening...
As long as the choke is opening properly as it warms, no worries.
leaking fuel well plugs or accelerator passage lead plug...
This is a chronic issue with QJets and results from their method of construction.  It's correctable by burnishing the secondary fuel well protrusions and sealing them with Devcon or JB Weld.  Same approach is used for the accelerator pump passage plug.
idle mixture screws set too rich...
You are probably close on your mixture adjustment, assuming smooth idle and no black or noxious exhaust fumes.
air bleeds plugged...
If the idle bleeds are plugged with dirt/debris, you might experience idle and transition problems.  Plugged main bleeds can cause early main nozzle tip-in and higher fuel consumption.  Watch the main nozzles at idle and off-idle; there should be no fuel emitting from them.  High float setting can also cause early tip-in.
vacuum hoses improperly routed/connected...
pics attached of the vacuum hoses.
EGR should be connected to ported vacuum, generally through a TVS/PVS.  The pull-off is plumbed correctly.
Offline slammed79
« Reply #7 on: May 11, 2013, 03:26:50 pm »
It isn't hooked into the hole, I made darned sure of that. Unfortunately the gauge and the chart are not with me anymore. I didn't throw them out, I just can't for the life of me figure out where I put them.
Do you happen to know the float level for that carb, or where I might find it on the interwebs?
I'll get the vacuum hoses swapped around after I put the carb on again.
Praise the lowered
« Reply #8 on: May 11, 2013, 04:57:29 pm »
Adjustment Parameters for 17058212:
Float Level =  7/16"
Pump Rod Location =  Inner
Choke Fast Idle Cam =  42°
Front Choke Pull-Off =  26-1/2°
Secondary Air Valve Spring Windup =  7/8 Turn
Choke Unloader =  43°
Fast Idle Speed =  1,700 RPM in Park/Neutral
One more thing to verify while the bowl cover is off:  Make sure the accelerator pump discharge check ball is in place under its retaining screw.
Offline slammed79
« Reply #9 on: May 11, 2013, 06:27:08 pm »
Thanks BD!
Praise the lowered
