Author Topic: Grinding when off the throttle  (Read 3393 times)
Offline Swamp82
« on: May 15, 2013, 06:01:08 pm »
ok so got the truck running good enough to take it for a drive today and and when i let off the gas there is a nasty grinding noise (sounds like gears grinding) i get back on the gas it stops, also when i let off and it starts grinding if i manually downshift while its grinding it stops making the noise ..so i went home and removed the front drive shaft just to see if there was any change..and nope no change. good i cant hear for sure where its coming from but the fact that it stops when i downshift leads me to think a transmission problem? its a 700r4... any help would be greatly appreciated.
Offline Engineer
Re: Grinding when off the throttle
« Reply #1 on: May 15, 2013, 06:58:46 pm »
I am afraid you are correct- tranny problem.
If it were the coast side of the rear axle ring+pinion it would do it in all gears.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline Swamp82
« Reply #2 on: May 15, 2013, 07:22:41 pm »
yeah it seems to be just in overdrive and drive at about 30 mph and up..
  thanks
