Diesel Engine Discussion
Question: Starter kicks out????
Topic: Question: Starter kicks out???? (Read 23982 times)
Dirty Offio
May 16, 2013, 12:57:14 am »
Hey guys,
So the starter on my 86 6.2L is pissing me off. If it is plugged in (even now, when the temps are nice) it will fire right up. If I try to start it if it hasn't been plugged in, the starter will start to roll the motor over and then kick out. Sometimes it rolls over several revolutions, other times it doesn't make it a full turn before it kicks out.
So my question is this. Do you think this is the starter drive? as in, if I pull the starter and change the starter drive will it start playing nice with the other kids? Or do you think it would be the solenoid? The starter works great, other than this...so I don't really want to swap the unit out...besides, the dang things are expensive!
Any help would be appreciated.
Thanks!
Offio
Re: Question: Starter kicks out????
May 16, 2013, 07:48:46 am »
does it do this with the motor hot (other than warm) and cold?
Dirty Offio
May 16, 2013, 09:31:22 am »
No, it only does it when the engine is cold and it hasn't been plugged in. If it is warm, it does not do it, if it is plugged in it does not do it. Overnight temps right now are in the 50's, so I shouldn't need to plug it in...other than this stupid habit of it's.
Cheers!
bake74
May 23, 2013, 07:19:36 am »
To answer your question we would need to know if the solenoid is loosing power when the starter "kicks out".
As you know, the solenoid only uses a small amount of current to connect the battery and starter. So during the "kick out", is the problem with the solenoid losing power, or, the actual starter loosing power from the battery ? Starters can draw up to 500 amps, and a lot of ignition systems have resistance wires built into the circuit to avoid over a ping and catching the system on fire.
You need to do a couple of test when cold. 1st test the solenoid power leads while starting cold to see if it is loosing power during the kick out. This will give you a direction to start your diagnosis procedures, either with the solenoid, or the starter/ignition system.
Report back your findings.
74 k10, 77k10 Tom
May 23, 2013, 03:24:44 pm »
while your doing that test does the starter Bendix(gear) still turn when the starter kicks out? you would hear a loud starter spinning noise
74 C-10 Shorty
June 22, 2013, 08:12:46 am »
Starter drive, clutch is bad that's why it zings..
zieg85
June 22, 2013, 09:32:29 am »
Classic description of a Bendix in need of replacement... (zings under extreme pressure like thicker oil of a cold engine).
74 C-10 Shorty
June 22, 2013, 09:59:34 am »
Yep, they're a one way clutch and it just won't hang on anymore, more pressure worse it is and it just keeps getting worse.
Dirty Offio
August 16, 2013, 06:14:51 pm »
Just a quick note. Thanks everyone for the replies. I replaced the starter drive and the solenoid. She works like a champ now!
August 16, 2013, 11:07:09 pm »
glad you got her fixed
