Author Topic: Temp gauge question  (Read 24251 times)
Offline Lowhoe775
Temp gauge question
« on: May 22, 2013, 08:58:14 am »
Hello i have a 78 c10 inline 6 (250). My temp gauge after it warms up stays a little over the first mark. I can run it all day and it does not move. Is this accurate for normal running temp. I think its too cool but i do not know anyone else with an inline 6 thanks in advance for any help
Offline 74 C-10 Shorty
Re: Temp gauge question
« Reply #1 on: May 22, 2013, 09:07:21 am »
Could be the sending unit??, but I would pull the T-Stat and check it on the stove in a pot of hot water, I always check new ones before I put them in even new ones are way off sometimes.
Offline 81_Chevy
« Reply #2 on: May 22, 2013, 09:37:34 am »
it could be your thermostat, since it could be stuck open not letting the engine warm up, check that first. it could also be your gauge and or temp sending unit. also after running your truck for a while (if it has heat) check the heater hoses, the both should be around the same temp, fairly hot to the touch. if there not hot its probably your thermostat, but if they are hot its more than likely you sending unit/ gauge. has the truck sat for a while without being run?
oh and welcome to the forums! drop by the welcome section a make a post!  8)
-Nic
Offline travisr1988
« Reply #3 on: May 22, 2013, 11:11:28 am »
My '79 c20 with a 350 has that same issue. I'll replace the tstat and check the new one in a pot. If that isn't the issue I'll replace the sending unit
1979 Chevrolet Silverado C20 rclb cammed 355/th400/4.10 - sold
1977 Chevrolet Custom Deluxe c10 rcsb stepside 355/th350/3.42
Vortec heads lunati cam edelbrock intake headers
Offline rich weyand
« Reply #4 on: May 22, 2013, 02:10:20 pm »
'78 K10.  Same thing.  Only time I saw it go up is when I had a coolant leak, and the sensor was uncovered.
Offline Lowhoe775
Temp gauge question
« Reply #5 on: June 01, 2013, 02:03:20 am »
Thanks a lot to everyone that gave me feed back i will try the tstat and go from there.. Ill post up the results thanks agiain
Offline Lowhoe775
Temp gauge question
« Reply #6 on: June 01, 2013, 02:09:12 am »
@81_Chevy the truck did sit previous owner past away and sat for about a year then i picked it up. It runs like a champ.
« Reply #7 on: June 01, 2013, 03:16:59 am »
not going to guess but heres how to test the sending unit if your sending unit changes in resistance then it would be your gauge or maybe bad connection. if no change check your hoses like stated if you notice them changing temps after the gauge stops rising then it points to your sending unit
Special thanks to bd for providing info on this
TEST PROCEDURE - SENDING UNITS
The subsequent charts provide precise sender resistance values for three specific gauge readings (Low, Medium, and High), hence, can be used to estimate sender resistance when actual physical parameters are known (e.g., engine temperature that is verified with a thermometer, actual fuel tank level, engine oil pressure that is verified with a manual gauge, etc).  Therefore, a sending unit’s resistance can be measured and “subjectively” compared to its interpolated value between ‘Low,’ ‘Medium’ and ‘High,’ based on the charts and the observable/verifiable physical conditions that actually exist on the vehicle.
For Truck Years:  1974 - 1978
The Temp Gauge Needle Should Point to:
Left Line (Cold) when sender resistance = 350 Ω
Middle Line when sender resistance = 68 Ω
Right Line (Hot) when sender resistance = 46 Ω
http://forum.73-87chevytrucks.com/smforum/index.php/topic,25339.msg211241.html#msg211241
Offline travisr1988
« Reply #8 on: June 03, 2013, 03:06:59 pm »
My fan belt (new one) broke the other day and my gauge definitely works, went up and almost overheated before I caught it, luckily I didn't throw the old belt away yet. I think the parts guy gave me a 160* tstat instead of a 195*. I'll have to be a jerk when I get the new one.
Offline Lowhoe775
Temp gauge question
« Reply #9 on: June 17, 2013, 12:30:26 am »
thanks for help so i checked the sending unit and it was working fine so i changed my gauge from one at a local junk yard and now it reads normal temp. So the problem was the gauge that was stuck and not reading correctly. Thanks
Offline Lowhoe775
Temp gauge question
« Reply #10 on: June 17, 2013, 12:33:33 am »
Problem was the gauge itself. Sending unit was fine and t stat was good too. If u have this problem try switching out the gauge. I got mine at local junk yard for 5.00 bucks easy to replace and now it reads normal thanks to everyone for the help
