Author Topic: Hooking up a factory tach cluster  (Read 5210 times)
Offline slammed79
  • Thou shalt not drive stock
« on: May 28, 2013, 08:19:33 pm »
I've got my eye on a factory tach cluster thats on local craigslist. My question is, if I can land it, do I just plug my connector into the back and go about my business or is there some wiring modification to do?
The tach cluster is a 73-75 judging by the ammeter, and it will be going into my 74.
Thanks in advance folks.
Praise the lowered
Offline Jason S
Re: Hooking up a factory tach cluster
« Reply #1 on: May 29, 2013, 09:44:47 pm »
As long as the cluster is the correct model year: The only wiring that would be needed are for the tachometer. The dash cluster plugs directly into the tach cluster the same as the non-tach cluster.
Offline dalefan613
« Reply #2 on: June 09, 2013, 02:30:11 pm »
I too have my eye on a factory tach I have a 75 bb with HEI will it too work ?
