Author Topic: Sump removal  (Read 4509 times)
Offline Bitzer!
  • Smiles per gallon
Sump removal
« on: June 14, 2013, 03:14:11 pm »
Hi guys, just a quicky!
Is it possible to remove the sump while the engine is still bolted in place? It looks like there is room to manoeuvre it out but I don't want to drain/unbolt only to find the engine needs to be lifted.
Any ideas if it can be done?
Cheers
Andy
1979 GMC CrewCab  C20 1t
Re: Sump removal
« Reply #1 on: June 14, 2013, 11:32:02 pm »
This on the crew or the Blazer?  I have done them with it still bolted in the truck.
Offline Bitzer!
  • Smiles per gallon
Re: Sump removal
« Reply #2 on: June 15, 2013, 01:52:03 am »
It's on the crew. Developed a leak that needs doing if I'm going to put the ole girl to work!
Going to attempt the gasket change with the engine in situ, I really don't wanna be taking it out agin!!
Re: Sump removal
« Reply #3 on: June 16, 2013, 10:30:16 am »
It should come out of the crew with it in place.  Most of the ones I have dropped were 2wd.
Offline Bitzer!
  • Smiles per gallon
Re: Sump removal
« Reply #4 on: June 20, 2013, 04:46:24 pm »
Cheers Chris, played about with the g/box sump & gasket today! Too many leaks!!
