Author Topic: Door Panels  (Read 7724 times)
Offline Old GMC
Door Panels
« on: June 21, 2013, 12:23:13 pm »
Will the door panels interchange between 73-87?  I know the doors are different part #'s but will the panels fit?
Re: Door Panels
« Reply #1 on: June 21, 2013, 02:54:50 pm »
73-76, 77-80, then 81-87.  The 77-80 will go on the 81-87 and back however the trim won't line up and match.
Offline Old GMC
Re: Door Panels
« Reply #2 on: June 21, 2013, 07:05:20 pm »
Thanks for the reply zieg85.  When you say the trim won't line up, just what are you referring too?  I am installing power windows in my 73 and will be installing new panels.  I want to use newer panels with no window crank holes.  I was hoping the 81-87 panels would fit my 73 without much modification.  Possible?  Is there really a big difference to the inside of the doors between years?
Re: Door Panels
« Reply #3 on: June 21, 2013, 08:03:52 pm »
Re: Door Panels
« Reply #4 on: June 22, 2013, 12:18:24 am »
Yes the different is significant.
Offline Old GMC
Re: Door Panels
« Reply #5 on: June 22, 2013, 02:47:44 pm »
Thanks all for the info, will be installing aftermarket power window regulators so I think I'll try the 81-87 panels, how hard can it be right!  Thanks again for the info. :)
