Author Topic: Bolts and Hardware  (Read 6084 times)
Offline 1984 K20
Bolts and Hardware
« on: December 15, 2004, 09:22:00 pm »
Does anyone know where I can get all the bolts and hardware I need to attach the front and rear axles.
Thanks
Offline RSBAD454
Re: Bolts and Hardware
« Reply #1 on: December 15, 2004, 08:42:00 pm »
can you elaborate a little more......what bolts/hardware do you need?
Toys are my game
http://
Offline 1984 K20
« Reply #2 on: December 16, 2004, 09:11:00 pm »
Well I have a bare frame with only the brackets that are riveted on to it. I need the shock mounting bolts,front sway bar bolts, and I need all the bolts that connect the springs to the hangers and shackle assemblies. I also need the bolts that mount the cab, box, radiator, and the rest of the drive train, but I'm not to the point of putting the body and drive train on yet. I hope this helps.
micrys5150
  • Guest
« Reply #3 on: December 31, 2004, 10:16:00 am »
  Truck catalog has all of the bolts, fasteners, bushings and parts you'll need for this. www. competitor.com.  Good Luck!Mike and Crystal
Offline roundedline
« Reply #4 on: December 31, 2004, 01:29:00 pm »
Any local Bolt store should have the bolts/nuts you need.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline 1984 K20
« Reply #5 on: December 31, 2004, 06:48:00 pm »
I'm gonna go with   and some of Lawson's hardened steel grade 8 bolts for the hardware. Thanks
