Author Topic: rear sliding window gasket  (Read 4728 times)
Offline jrbarrie83
« on: June 29, 2013, 02:51:25 pm »
I need to replace the rubber that sits in the channels above and below the sliding glass in the rear window.  Mine is severly dry rotted and beyond help and the window can only be open about two inches.  First, where can I find this?  Second, how does one go about replacing it with the window still in the truck?  I assume I would just slide it in from one end over/under the sliding panels until it reaches the other end, but how would I go about gluing it in with that method?
A side question - would it just be easier/better to replace the entire window?  It seems to be in decent shape, but would an aftermarket one look and function better in the long run?  How much of a task is this?
I searched the site, but the other posts I've read about this topic didn't quite seem to answer this question.
Re: rear sliding window gasket
« Reply #1 on: July 09, 2013, 10:55:39 pm »
Don't know anywhere you can find that.
Offline jaredts
« Reply #2 on: July 10, 2013, 03:58:53 pm »
Mine has felt strips, is that what you are asking about?
Offline Silverado1979
« Reply #3 on: July 21, 2013, 12:22:58 pm »
That's a repair you might have to improvise yourself. Try to find new rubber or felt strips. You could just try to put silicone on the dry rotted rubber, but I doubt that would work.
Offline Powerdriver1958
  • Kids Mechanic
« Reply #4 on: July 21, 2013, 12:33:16 pm »
I've had 4 different sliding back windows over the years and everyone of the dern things was built different . Your in for a good hunt I believe . That being said I know that in KC there is one company that has window seals of all sizes and shapes ,  maybe an outfit like that might help or at least point you in the right direction
I Have My Grand Daughter Exactly Where She wants Me
