Author Topic: Relocating the Fuel filler tube  (Read 8878 times)
Offline 82BlazerMan
    • Blazer pics
« on: July 01, 2013, 12:49:35 pm »
Hey guys, I've some 2" drop shackles I'm trying to install.  Anybody got any ideas or pictures of relocating the fuel filler tube?  I might use a flexible radiator hose, but I don't think I can make to turn sharp enough.  Any help and/or pictures would be appreciated.  I beleive this also has to be done on suburbans too if you use shackles.
1982 Blazer 2WD
305ci
700R4
Offline 82BlazerMan
    • Blazer pics
Re: Relocating the Fuel filler tube
« Reply #1 on: February 04, 2014, 11:10:22 pm »
Well, I installed the shackles and just put a longer fuel hose. Rubs a little so I'll keep an eye on it
Sent from my SAMSUNG-SGH-I317 using Tapatalk
1982 Blazer 2WD
305ci
700R4
« Reply #2 on: February 04, 2014, 11:43:32 pm »
couple things, one i dont thing rad hose is rated for fuel and two rubbing on fuel line your kind of asking for a problem
« Reply #3 on: February 05, 2014, 10:28:46 pm »
Irish is right.  That radiator hose isn't going to last long.  If you need fuel rated flexible hose check with a boat shop.
