Author Topic: Brakes causing miss and stall?  (Read 4350 times)
Offline MyOldScottsdale23
« on: July 04, 2013, 09:57:38 pm »
I just recently put a crate engine in my 1985 GMC K10 Sierra Classic. It sat for a few months in a field. Since I've had it running when I press the brake pedal all the way I here an air leak under the dash and the engine will miss and stall. Any suggestions?
Re: Brakes causing miss and stall?
« Reply #1 on: July 04, 2013, 11:22:46 pm »
Replace the power brake booster.  Make sure the vacuum hose supplying the booster is in good shape.  The "air leak" is a ruptured diaphragm in the booster.
« Reply #2 on: July 04, 2013, 11:48:45 pm »
« Reply #3 on: July 05, 2013, 05:54:19 pm »
Will do. Thanks. I'll let ya know how it goes.
Offline Fairlane514
« Reply #4 on: July 05, 2013, 07:09:01 pm »
You may try a new check valve.....its easy and cheap before you have to replace the whole booster.  Its the plastic piece in the front of the booster where the vacuum line plugs into.
