Author Topic: carbureted 350 to injected 454 swap guidance please  (Read 4057 times)
Offline lscotty
« on: July 11, 2013, 12:02:21 am »
I have a 77 k20 chevy that has a carbureted 350 and I recently aquired a 91 chevy 1 ton that has a fuel injected 454. I plan to replace 350 with the motor transmission and transfer case from the other truck and wanted to see if I was missing any parts in doing the swap. Im plan to pull the 454 with the wiring harness computer and everything along with the radiator, fuel pump, sending unit (possibly the whole gas tank) and ive read I'd also need to either swap the fuel lines or replace them with a proper setup but am not 100% sure about that yet, need the speed sensor, rig up a check engine light (so possible pull guage cluster and associated wiring from donor truck), and the obd plug . Is there anything I'm missing that also needs to be swapped? Or any thing i listed that i dont need to do. Also any problems or complications I may run into in the process. I know my way around working on and fabing stuff but its the first time I've attempted something like this. I tried google for hours but never really found anything. It all had to do with conversion kkits or going from tbi to carb nothing about a full carb to injection motor swap. So any input you may have good bad or whatever  to make sure im on the right track and not missing anything impotant is greatly appreciated.
Re: carbureted 350 to injected 454 swap guidance please
« Reply #1 on: July 11, 2013, 12:16:13 am »
dont know in your case but sometimes it easier to swap frames or just swap cabs.
« Last Edit: July 11, 2013, 12:18:23 am by Irish_Alley »
Offline lscotty
« Reply #2 on: July 11, 2013, 01:55:00 am »
Thanks for the reply but frame or cab swap would be easier motor wise but the 77 is my toy and I've already built up the front and rear suspension, got lockers and some minor body mods to fit 39 inch tires. Everything is set up and dialed in how I want except the motor. I did everything knowing a 454 would be going in at some point and the donor truck was offered to me for free from my brother in law so im ahead of the game already even if it's going to be a little more work. Just want to make sure ive got a good plan layed out and im not missing something before I get started.
« Reply #3 on: July 11, 2013, 03:25:28 am »
in that case, this isnt a 454 but its a ls and i would think it kind of the same ideal
http://forum.73-87chevytrucks.com/smforum/index.php/topic,12120.0.html
Offline lscotty
« Reply #4 on: July 12, 2013, 09:03:07 am »
 :-[Its definitely a 454. That link still had some good info. Not exacrly the same but similar. Im definitely not going as in depth or changing stuff like that. Just puting the motor in and making it run. Thanks for the reply its still helpful
« Reply #5 on: July 12, 2013, 11:02:54 pm »
lol wasnt saying yours wanst a 454 but was saying that post i posted wasnt. kind of give you an ideal what to grab computer wise. ill keep an eye out for a post that fits your needs
