Author Topic: Front right clicking noise !  (Read 9568 times)
Offline 86grannygear
« on: July 20, 2013, 01:10:45 pm »
86 c10 custom deluxe 8 ft bed
New rubber
- upfront / Mickey 255/60/15
- outback / Mickey 295/50/15
New rims
- upfront / cragar smoothie 15x8 rear spacing 4-1/4"
- outback / cragar smoothie 15x10 rear spacing 4-1/4"
It sounds like the front right is clicking now... The previous rims/tires never made the noise .... Drove truck last night and was fine ... Slapped the new tire/rims on and took for a spin and now wouldn't you know I have noise now ... Eye balled it and I can't see anything rubbing ...
Any ideas what's wrong ? Do I Need a spacer upfront ?
Thanks guys !
Re: Front right clicking noise !
« Reply #1 on: July 20, 2013, 11:22:41 pm »
try to tighten you lug nuts a little more. i did that once on my 94 didnt quite get them tight enough, can remeber if it wobbles or clicked
« Reply #2 on: July 21, 2013, 07:31:06 am »
Gonna try and figure it out this morning ...
Thanks for the reply !
« Reply #3 on: July 21, 2013, 07:37:25 am »
If you have aftermarket rims and the center cap just slides in from the back it may be loose and that is what you are hearing???
Offline Powerdriver1958
  • Kids Mechanic
« Reply #4 on: July 21, 2013, 07:50:10 am »
If you put light pressure on the brakes and the clicking sound go's away its prob the brake pads
I Have My Grand Daughter Exactly Where She wants Me
« Reply #5 on: July 22, 2013, 07:18:29 am »
Thanks for the replys !
The darn noise was from the weights behind the wheel . Every revolution the weights would click the caliper... The tire shop put 2 rows of weight ( the sticky kind ) on top of each Other ... So it's built up pretty high ... Weird but the front left has only 1 row of 6 and the front right has 1 row but 2 high of 6 for a total of 12 ....
Hmmmm...
Offline Tx_Phil
« Reply #6 on: July 22, 2013, 11:34:06 am »
You might ask the tire shop to break that one tire down and rotate it 180 degrees on the rim. This should change the amount of weight needed to balance the tire. Hopefully they can go back with only a single stack of weights.
« Reply #7 on: July 25, 2013, 07:50:55 pm »
     You can also see if the tire shop does Road force testing.  This is where they remount the tire until the lightest weight/no weight is used.  This cost extra at every tire shop I have ever been to.
Offline 4x4x4x
  • 85k10 diesel
« Reply #8 on: August 08, 2013, 10:11:40 am »
your post got me thinking about a clicking noise on my truck. (noise started after adding new tires).  went to the tire store to have them check out the noise, and surprise!!!!!, the noise was from the old set of center caps on my front wheels, the caps had some rust on them, so it was a no brainer to replace them. about $15.00 later I was out the door and running with no more clicking noises from the front end.  it's a diesel so there is still plenty of noise from the engine though.
85 k10 swb, 6.5 diesel. banks sidewinder turbo, 700r4, auburn gear ected limited slip/lockers f & r, 411 gears, front slotted disks, rear disk brakes, 4"exhaust,  cibie headlight and fog lights, rancho rear spring lift, rancho shocks, new ft. springs,
