Author Topic: Tips for removing the gas tank? - 1987 Silverado  (Read 6411 times)
Offline Mike Phillips
« on: July 21, 2013, 08:12:48 am »
Two issues...
1. Gas gauge isn't reading correctly.
When I fill it up the gauge read about 1/3 full.  When she's empty it reads just under 1/4 on the gauge.  So while I can monitor when I'm getting low I'd like to get the gauge to work correctly.  Not sure if this is the sending unit or the gage or something in-between.
2. Want to install a set of Super Hoops
Wife has a hard time getting into the truck and bought me a set of Super Hoops.  The passenger side looks like a pretty easy install but to mount the mounting bracket it looks like the gas tank will need to be removed.
Any tips or suggestions?
Offline winky
Re: Tips for removing the gas tank? - 1987 Silverado
« Reply #1 on: July 21, 2013, 03:55:38 pm »
I believe there's 8 bolts holding the fuel tank on (4 on each side) I think I had to stick a wrench between the tank and frame to hold the bolt while I used a ratchet on the back side of the frame. This will unbolt the bracket holding the fuel tank. As far as the hoops I have no experience
« Reply #2 on: July 21, 2013, 07:25:21 pm »
Tip- empty the tank
Offline thirsty
    • Suitor's Garage
« Reply #3 on: July 21, 2013, 07:54:39 pm »
Tip #2 - don't forget the ground strap.
And wear some eye protection. Speaking from experience on that. ;)
Offline gildardo01
« Reply #4 on: July 21, 2013, 08:06:59 pm »
you can used an impact wrench or something to remove the bolts quickly.. and to lower it i like to use a floor jack...
Offline winky
« Reply #5 on: July 21, 2013, 08:51:25 pm »
Oops forgot to mention the tips. Lol
