Author Topic: 1983 gmc 305 w/quadrajet carb1009ccd  (Read 3594 times)
Offline chuck grey
« on: July 23, 2013, 07:14:23 pm »
first road trip in truck texas to colorado drove with no problems.carrying a nissian twin turbo motor.parked it for three days didn't want to start for two days after that.gave it bg treatment over counter .started after that but wouldn't stay on long enough to warm up.would die if i let it idle by its self two three times.then it got over that point .swapped the back vacuum linesstayrd one i drove it a couple on hours park didn't want start back..left it alone few hrs. started on first try but than once again i turn it off it wouldn't start gotta just leave it alone for while ..also removed right fuel tank forgot what line goes where....help
Offline 454Man
  • Why Race?
Re: 1983 gmc 305 w/quadrajet carb1009ccd
« Reply #1 on: July 23, 2013, 08:12:53 pm »
First thought ignition cool it ignition module
« Reply #2 on: July 24, 2013, 02:18:53 pm »
Man I'm having problems reading your post. What vehicle has twin turbos? When you say didn't want to start for 3 days is this your call or you tried to start but never wanted to run. What's a BC treatment, why did you do this. Now after you got it started and it warmed up you shut it off or did it just die? Then after sitting you started it then did you shut it off or did it die. Why did you remove the gas tank?
Offline CanadianC10
« Reply #3 on: July 28, 2013, 09:53:30 pm »
I agree with Irish alley on your post, I can't understand enough to help, as for the fuel tank, largest (3/8 nipple) is feed,    Medium (5/16 nipple) is return and the smallest (1/4 nipple) Is for your coal canister, If equipped I'm pretty sure
1984 C10 LWB
CADDY 507
TH400
Frame twister
12.59 @ 108 .. 1.94 sixty
