Author Topic: 86 Scottsdale w/ a 305 small block  (Read 13884 times)
Offline rich weyand
Re: 86 Scottsdale w/ a 305 small block
« Reply #15 on: August 02, 2013, 11:06:30 pm »
one back fire and you got a nice little fire going
Not into the throat of the carb, into the fuel inlet.
« Reply #16 on: August 02, 2013, 11:09:35 pm »
Do not run the motor while pouring gas into the carb.....(it kinda sounds like what you are describing)  Run a rubber hose from your gas can to the inlet on the fuel pump.
going off what he way saying sorry buddy
Offline okas271129
« Reply #17 on: August 06, 2013, 12:17:05 pm »
Any advice on removing carriage bolt from a truck bed?  Down to the last 2 ..the closest to the cab and there extremely tight .. already use penetrating oil / breaker bar / power tools. Don't have a tourch or plasma cutter . Just a angle grinder
« Reply #18 on: August 06, 2013, 01:16:29 pm »
Go get a little propane bottle set up, the kind used to solder copper pipe.  It takes a while but you can get enough heat to it to break loose
Offline jaredts
« Reply #19 on: August 06, 2013, 07:51:58 pm »
Just use the angle grinder (carefully).  I guessed more or less where the square hole would be in the bed floor and cut straight down in four places on each head, cutting four little pieces off so the bolt would just fit through.  Took about two minutes per bolt.
« Reply #20 on: August 06, 2013, 11:00:15 pm »
wear safety glasses no mater which way you take.
Offline okas271129
« Reply #21 on: August 08, 2013, 10:15:36 am »
Carriage bolts on the truck bed are being a royal b*tch got 6off so far last 2 by the cab are so tight I can seems to loosen bolt started stripping .. advice please  I don't have a tourch or plasma cutter
Offline rich weyand
« Reply #22 on: August 08, 2013, 11:34:26 am »
These are handy.  http://www.northerntool.com/shop/tools/product_200396173_200396173?isSearch=9094281
Only goes to 3/4", but those should be 1/2-13 carriage bolts with 3/4" nuts.
« Reply #24 on: August 08, 2013, 11:35:03 pm »
read the reviews for advance and autozone lol stay away from those two
