Author Topic: starting to get things sorted on the project truck  (Read 18645 times)
Offline moregrip
« on: August 08, 2013, 09:18:24 am »
pulled the trigger, parts are ordered! No going back now.
Going to address the suspension first.......hoping for a great stance and a great ride!
Parts List:
1. Belltech 4/6 drop kit with Street Performance Shocks(3" spindles/1" springs/flip kit/c-notch)
2. Porterbuilt 1" forward tubular lower control arms/delrin bushings/ for stock coil spring application(centers front wheel in wheel opening correcting the known visual flaw when lowered/adds considerable castor gain approx 7 deg)
3. Stock upper control arms with MOOG K6184 problem solver control arm shafts/bushing kit(allows additional positive camber adjustment)
4. Stock rear leaf springs and shackle w/Energy suspension bushings(have run these before and like them alot)
5. Energy suspension body mounts
6. McGaughy's 12.5" Front Disc Brake Kit part# 63156
7. MOOG tie rods/adjustment sleeve/idler/pitman arm/ball joints
8. Dorman lower control arm bolts
Should be a good start to a nice riding truck!!
Offline FlatBlack77
Re: starting to get things sorted on the project truck
« Reply #1 on: August 08, 2013, 10:54:07 pm »
in for this!
how much did the moog parts cost all together?
im about to pull an $800 trigger on parts to finally get mine back on the road and a few front end parts are on the list
Offline moregrip
« Reply #2 on: August 08, 2013, 11:24:43 pm »
Not sure. I'll add it up and check back in :)
« Reply #3 on: August 08, 2013, 11:44:33 pm »
     Make sure you take lots of pics of your progress.
Offline burbboysgc
« Reply #4 on: August 09, 2013, 03:22:58 am »
 Is the Moog control arm shaft stock to the C10's? How does it give more of a positive camber adjustment? Never heard of this and wold like to know more.
1987 C20 3/4 suburban 454 tbi th 400/2wd - 1985 C10 short bed 305/350 turbo 2wd
1979 swb Custom Deluxe 2wd roller
Offline moregrip
« Reply #5 on: August 09, 2013, 07:21:18 am »
will do!
Offline moregrip
« Reply #6 on: August 09, 2013, 07:24:36 am »
Me either. From the pic on Moog's website it looks like an offset shaft. I haven't taken delivery yet to verify but it's a part of their "problem solver" line.
http://fme-cat.com/overlays/part-detail.aspx?brand=MC&PartNumber=K6184&pt=Suspension%20Control%20Arm%20Shaft%20Kit&lu=1973%20CHEVROLET%20C10%20PICKUP&vin=#.UgTfeNLFV8E
Offline moregrip
« Reply #7 on: January 04, 2014, 04:06:43 pm »
cleaned up and ready for service:
Offline moregrip
« Reply #8 on: January 04, 2014, 04:09:13 pm »
I wanted to add power steering and air conditioning. Can't afford the A/C part right now so I'll only be adding the power steering to the in-liner.
Using these brackets:
[/QUOTE]
Offline moregrip
« Reply #9 on: January 04, 2014, 04:10:29 pm »
Going to give the Weber 2 barrel (38DGES) a try on top of a Clifford intake manifold:
Offline moregrip
« Reply #10 on: January 04, 2014, 04:11:49 pm »
took delivery on a non integrated small chamber head. Should bump up the compression ratio from approx 8.5-1 to 9.5-1.
Offline moregrip
« Reply #11 on: January 04, 2014, 04:12:47 pm »
got some work done over the holiday break, was able to repair the front drivers frame rail that was bent.....well replaced it anyway.....good as new!
« Reply #12 on: January 04, 2014, 08:15:54 pm »
     Nice progress so far, are you doing anything besides head and carb. for the straight 6 ?
Offline moregrip
« Reply #13 on: January 04, 2014, 09:06:44 pm »
Thanks.....Other than the Clifford intake manifold and Weber Carb, I'll be installing Clifford shorty headers, a nice exhaust system (probably a two into one setup), new harmonic balancer, alternator, power steering pump.....stuff like that. Maybe a hotter cam in the future but not during this project.
Offline dvdswan
« Reply #14 on: January 05, 2014, 11:03:05 am »
awesome work.
