Author Topic: drive shaft help  (Read 5139 times)
Offline winky
drive shaft help
« on: August 20, 2013, 10:25:20 pm »
I'm building a truck its a half ton truck. I put a Dana 60 and 14 bolt off. And a 205 t case with 6" susp lift. I need drive shafts made due to the amount of lift and since I  installed a 205 (its not the slip yoke kind.)
I'm going to do some calling tomorrow. But would it be better to buy a used set of drive shafts and have them modified? Or just have some made from scratch? Any input would be appreciated
Re: drive shaft help
« Reply #1 on: August 21, 2013, 12:15:39 am »
well to start what trans, and you said you have the flat face that bolts to another flat face, not the u bolt type cause they both have slip yokes.
« Reply #2 on: August 21, 2013, 12:21:54 am »
anyway you can use a stock shaft. i have one in my k20 im only breaking axle shafts. but even if you go with a smaller shaft you can go to napa tell them what you have and what you need they will get you the u joint out of the parts catalog. i know autozone has the books but when i worked there i had to clean them off before i used them due to dust. but find a drive shaft that came off a k30 or if you have to a k10 just have to get the right u joint to match the dana 60 the rest will be the same
Offline winky
« Reply #3 on: August 21, 2013, 10:08:26 pm »
My bad. Meant slip yoke as in drive shaft sliding into t case like a 2wd auto trany.  Sm465 trans 205 t case I have a 1410 ford output on my t case. I think... I'll find out for sure. Here t case pic to clear up.
« Reply #4 on: August 21, 2013, 10:55:28 pm »
i think/know i have one just laying around but its the stock size for a sm465/205. its what i ran the only reason i took it off is because the way it threads in, threw the back of the yoke on the t-case into the yoke on the drive shaft. wasnt a "bad" design imo but those bolts back out pretty easy and you dont know it till you need it then the other bolt/s will snap off. ill check today and see if i can find it and give you some measurement
Offline Jason S
« Reply #5 on: August 21, 2013, 11:01:44 pm »
Cutting a used driveshaft to length will cost less than building a new driveshaft.  If you can find a used shaft(s) that can be shortened you will save quite a bit of money.
If necessary, differing u-joint sizes between the driveshaft yoke and the t-case or axle can be remedied by a combination u-joint (I think Irish touched on this).
My $0.02:  If it were me, I would look for used driveshafts that had the same u-joint needed and desired length or longer than desired (fixed yoke style shafts with a slip joint) and have them cut to length as necessary. If nothing could be found, then I would look into having driveshafts built.
