Author Topic: Rear end clunk  (Read 9106 times)
Offline 85silverado031490
  • 1985 C10 LWB Daily
Rear end clunk
« on: September 01, 2013, 10:21:04 am »
Hey guys, i have an 85 c10 lwb and the previous owner had a 4" drive shaft custom built for the truck because i guess he thought it was necessary, any ways when im putting it from park to reverse or drive or neutral i always get a pop or clunk from the rear end no matter what, and when downshifting from 3rd to 2nd or 2nd 1st i have a small one as well; the pinion yoke will move side to side and up and down a small amount do i know that the bearing preload is not correct or completely nonexistent and that that would cause the gear mesh to be incorrect. My question is should i just replace the inner and outer pinion bearings and reset the crush sleeve and preload or go through the whole rear axle? Keep in mind that i am planning to switch out the stock le9 305 motor and install a mild 350 in place. I feel like the huge rotating mass of the heavy drive shaft is what killed the bearings in it, and i believe its the standard rear axle which is a 3.08 and i would like to switch the gears to a 3.73 or something a little smaller than that. If anyone has any insight as to this please let me know cause its driving me absolutely insane.  J.S.
> I Luv It <
Offline Powerdriver1958
  • Kids Mechanic
Re: Rear end clunk
« Reply #1 on: September 01, 2013, 10:42:19 am »
1st the step From 3:08 to 3:73 is a big one . 3:73 gears seem to leave me with a cruise rpm of 2,500 to 2,700 . Not fuel mileage friendly .
On 2 different trucks I found the spider and side gears to have a lot of wear and that was the cause . If you have any drive line problems at all that's where I would start ( 1st cheapest is generally where I start :) )
I Have My Grand Daughter Exactly Where She wants Me
Re: Rear end clunk
« Reply #2 on: September 01, 2013, 12:50:53 pm »
Ok I got ya on that, I guess the best thing to do is open up the rear axle and look at what I may or may not still have , ugh, heres a second one . Drivers side lower ball joint is spinning inside the control arm when I turn the wheel, ok so I was gonna buy new oem replacement arms from like dorman or somebody,  nope , the only options I see are on summit racing and they are all lower arms with a 3 inch drop for use with the stock coils, I have 32 by 11.50 by 15 inch tires coming this week for this truck and I am not gonna give up my tires because of this,so what in the world am I supposed to do? I know moot offers some specific ball joints that are a few thousands bigger as an option but I don't know if there are any for my application. Or should I just replace the lowers with moogs And see if they go bad again?
> I Luv It <
  • Kids Mechanic
Re: Rear end clunk
« Reply #3 on: September 01, 2013, 01:06:27 pm »
Salvage yard is next or it would be for me . I wouldn't take a chance on the control arm . Replace it , stuff a new ball joint in the salvage yard one .
« Last Edit: September 01, 2013, 01:09:11 pm by Powerdriver1958 »
Online bd
Re: Rear end clunk
« Reply #4 on: September 01, 2013, 02:23:42 pm »
1985 C10 ... Drivers side lower ball joint is spinning inside the control arm when I turn the wheel, ok so I was gonna buy new oem replacement arms from like dorman or somebody,  nope , the only options I see are on summit racing and they are all lower arms with a 3 inch drop for use with the stock coils, I have 32 by 11.50 by 15 inch tires coming this week for this truck and I am not gonna give up my tires because of this,so what in the world am I supposed to do? I know moot offers some specific ball joints that are a few thousands bigger as an option but I don't know if there are any for my application. Or should I just replace the lowers with moogs And see if they go bad again?
Napa - complete left lower control arm
Offline Fairlane514
Re: Rear end clunk
« Reply #5 on: September 01, 2013, 02:59:47 pm »
The way you describe your rear end, it should be whining a lot.....is it?
