Author Topic: crossmember swap on 85 2wd  (Read 6751 times)
Offline dale
« on: September 02, 2013, 07:38:22 pm »
Looking to swap the crossmember on my 85 chevy pro street project.. just got my 3" drop springs in  :D and now i want to swap upper and lower control arms... any ideas?
Re: crossmember swap on 85 2wd
« Reply #1 on: September 03, 2013, 01:46:36 pm »
I am not exactly sure what you are asking.
Offline dale
« Reply #2 on: September 03, 2013, 08:47:51 pm »
Wanting to unbolt the six bolts that hold on that huge crossmember and replace it with an aftermarket... is that possible?
Offline CanadianC10
« Reply #3 on: September 04, 2013, 06:27:23 pm »
There's five cross members from front to back..
1984 C10 LWB
CADDY 507
TH400
Frame twister
12.59 @ 108 .. 1.94 sixty
Offline dale
« Reply #4 on: September 04, 2013, 08:40:35 pm »
Hate to burst your bubble... But this 2wd lwb frame has 6 on it!
Offline CanadianC10
« Reply #5 on: September 09, 2013, 06:29:03 pm »
well if someone makes an aftermarket cross member you must be able to do it then or atleast that's my guess? And ok 6 I was going off the top of my head, if the truck has a steady bearing in it, or had a steady bearing then I can think of 3 "huge" crossmembers, up front between  the control arms, the rear cab support member which there are 2 versions of, 1 that is basically 2 mounts and a bar joining them and the other version is made alot heavier and able to support a steady bearing, then the crossmember between the front spring hangars, so be a little more specific and maybe someone will take the time and think about their reply
1984 C10 LWB
CADDY 507
TH400
Frame twister
Offline CanadianC10
« Reply #6 on: September 09, 2013, 06:29:37 pm »
Rear spring hangars*
1984 C10 LWB
CADDY 507
TH400
Frame twister
