Author Topic: change IFS to solid axle?  (Read 5201 times)
Offline jsaffle
« on: September 09, 2013, 09:10:37 am »
looking to change my 84 gmc 2wd lwb front suspension over to a solid front axle with leaf springs....for two reasons...right now i would like to get it off the ground around 4 inches or so..and second...eventually will add a transfer case and make it 4wd...any suggestions on how to go about...custom make hangers for leaf springs..or can I cut and weld ones from a C20?...any ideas? thanks
Re: change IFS to solid axle?
« Reply #1 on: September 09, 2013, 08:03:48 pm »
     First off welcome to the site.  You can unbolt and drill out all the rivets of your front suspension parts and use grade 8 bolts to bolt in the parts needed off a k-10.
     But more than likely you will need to find a donor vehicle for all the parts, and if you have a donor vehicle you might as well swap frames and just use the 4x4 frame and put your truck stuff on it.
Offline jsaffle
« Reply #2 on: September 10, 2013, 02:24:03 pm »
Thats what i meant k for 4x4...anyways if i go the route of a frame swap, my only cut/fab would be for the larger tranny/transfer care hump correct? Pretty sure the humps are a significant difference?...thanks
« Reply #3 on: September 10, 2013, 03:15:35 pm »
     Correct, the transmission hump are taller on 4x4's.
« Reply #4 on: September 11, 2013, 04:35:26 am »
you can beat your hump to fit the transfer case or swap humps or 3" body lift
« Reply #5 on: September 25, 2013, 10:23:28 pm »
buy this kit and put the rear springs from a donor on the front:
http://diy4x.com/cart/index.php?route=product/product&path=24&product_id=120
I cut all the brackets off my Blazer when converting it to 4x2, I am selling them also if you want them.
