Author Topic: testing pwer windows & locks  (Read 5504 times)
Offline oldfrt84
« on: September 13, 2013, 03:15:44 pm »
Got a set of nice '85 doors to go on my78 Silverado. They have power windows and door locks.Mine came with power windows but not locks.
I want to test the window motors and locks before mounting the doors. I found the schematic here but not too bright at electrical schematics. Also my eyes are kinda old and reading the schematic is tough. I was able to test the drivers side window motor by hooking wires from a battery to it. I put 12v on the pink wire and ground to the black & it worked! Passenger side doesn't appear to have a direct ground wire so it must get it somewhere else.
Anybody want to help an old guy out and tell me which wires on the harness going into the door at the hinge I need to hook power and ground to?  I'd like to test power door locks too so any help would be appreciated!
Offline rich weyand
Re: testing pwer windows & locks
« Reply #1 on: September 13, 2013, 04:04:37 pm »
Here's the wiring diagram for your power windows and locks.  Should give you everything you need.
http://www.73-87chevytrucks.com/techinfo/wiring_diagrams/powerwindows.gif
« Reply #2 on: September 13, 2013, 11:43:29 pm »
the right side gets its power from the left side so i would assume its the same with the ground. i want to sayif you go drk blue and brown on the motor itself this will work your just bypassing the switch, but idk i cant read these diagrams either
« Last Edit: September 13, 2013, 11:46:25 pm by Irish_Alley »
Offline oldfrt84
« Reply #3 on: September 14, 2013, 05:25:39 pm »
Thanks guys! I thought about going straight inside the door to the wires as you mentioned but wasn't sure what it might do to the switch.
I know there are some really smart guys here that tell me which wires to hook the 12v and ground to. Not sure what the door locks need as I think they have relays too. I'm not real good with reading electrical schematics!
« Reply #4 on: September 15, 2013, 11:06:42 am »
     You need to connect the doors together and test, that way you should be able to operate everything at once.
