Author Topic: What am I missing?  (Read 10184 times)
Offline ah1115
  • 1985 K10 shortbed 350 4speed
What am I missing?
« on: September 20, 2013, 10:25:18 am »
Im having a lot of play in my steering. The ball joints look to be bad. I'm ordering new upper/lower ball joints & inner out tie rods. Is there anything else you would recommend swapping while this is getting done? Im ordering today so any quick input will be appreciated.
Offline bd
Re: What am I missing?
« Reply #1 on: September 20, 2013, 10:32:11 am »
Check the inside of the frame around the steering box mounting very carefully for cracks.  The 4X4's especially have a tendency to crack there from flexing.  Have someone turn the steering wheel while you watch the gearbox for movement relative to the frame.
Offline ah1115
« Reply #2 on: September 20, 2013, 10:35:24 am »
Thanks!
Offline bd
« Reply #3 on: September 20, 2013, 11:02:41 am »
You're welcome!  I should have added, whether or not the frame is cracked, there are kits available to repair/prevent cracking, but if cracked, require welding.  See Autofab Steering Box Gusset Kit and Warrior Products Frame Plates.
Offline ah1115
« Reply #4 on: September 20, 2013, 11:06:11 am »
It doesn't look to be cracked. I was kind of wondering what else should I just swap while im in there. Picked up what I mentioned above and a tie rod sleeve. I think the bigger tires I recently put on just wore all this out.can you believe  Advanced wanted $393 for these parts and Jegs had the same ones for $278. These local parts stores have quite the markup.
Offline flips87c30
« Reply #5 on: September 21, 2013, 11:11:29 am »
I would replace all your u-joints in the front while your at it. Front axle u-joints and the front driveshaft. when my front driveshaft u-joing went bad it cracked in half and sent my driveshaft through the bottom of my freshly built transmission. So what Im sayin is always have new u-joints ;D
87 v30 duelly dump truck 454, th400, np205, dana 60/14 bolt, warn hubs, gmt800 mirrors and LEDs all around the bed.
Offline ah1115
« Reply #6 on: September 21, 2013, 04:05:03 pm »
That doesnt sound like a good time. I just might have to take that advice.
Offline flips87c30
« Reply #7 on: September 21, 2013, 11:22:24 pm »
Ya I was experiencing death wobble a few weeks back and it turned out to be a siezed up front axle u joint. changing them is cheap insurance.
« Reply #8 on: September 21, 2013, 11:39:44 pm »
flips sound like your double cardan joint failed. they need to be rebuilt also if your tearing it apart. the part number is 612-NUJ. its less than $30 and your drive shaft will be like new. also what type of tires do you have? and have you dont a dry test. get someone to turn/rock the steering wheel and see where it stops moving or where you see a lot of play
« Last Edit: September 21, 2013, 11:45:39 pm by Irish_Alley »
Offline flips87c30
« Reply #9 on: September 22, 2013, 09:10:55 am »
Death wobble is fixed now it rides like a dream.I replaced all tierod ends and my steering box (it leaked anyway). but the real culprit was my front axle universal.. back when the front driveshaft went, The double joint was fine it was the u-joint in the front that sheared. I had to find a new drive shaft at the junk yard and replaced the u-joint and double joint. After putting in a new transmission.
Offline ah1115
« Reply #10 on: September 22, 2013, 10:38:42 am »
Sounds like I better place another order as I have the death wobble as well. I've only had that going down feeling on 2 wheels. I tried to find that Cardan on jegs or advance. Where is that part number from? Also anyone know if this login is for the store login here? I cant seem to access it
« Reply #11 on: September 22, 2013, 07:34:36 pm »
I used it at Napa. They can cross it. Maybe auto zone can cross Napa number but I just felt with Napa on special parts
