Author Topic: Quick tip to repair cracks in Headers  (Read 6482 times)
Offline pedigo78
  • Big Blue
« on: September 20, 2013, 01:57:18 pm »
So I noticed I had some cracks in the headers and leaks. they prior owner had the entire exhaust welded so I have no flanges to remove headers and replace.  So ill need new headers and then take it to a shop to have new flanges welded on. But in the mean time could I hit the small cracks up with some apoxy or would the heat be to much? Also could the cracks be the reason I am backfiring at idle?
Sgt Pedigo USMC
Offline Fairlane514
Re: Quick tip to repair cracks in Headers
« Reply #1 on: September 21, 2013, 07:20:35 pm »
Weld the cracks......maybe the muffler shop can do it.  The cracks could be causing your popping sound at idle
« Reply #2 on: September 21, 2013, 11:28:50 pm »
dont waist money getting someone to weld the cracks. if they cracked they are rusty if you weld on rust the area next to the weld will crack. a patch job will work. they sell exhaust epoxy. i would op for jb but idk if it can handle the heat. seen it work on a block before just not the exhaust. and yes like fair said a leak will pop and almost sound like a knock sometimes
Offline pedigo78
  • Big Blue
« Reply #3 on: September 21, 2013, 11:37:13 pm »
thanks guys
Sgt Pedigo USMC
Offline rich weyand
« Reply #4 on: September 21, 2013, 11:51:22 pm »
There is such a thing as high-temperature epoxy exhaust repair, but it is not a long-term fix.  My epoxy repair on the exhaust pipe lasted about a year and a half, and it doesn't get near as hot as a header.  The use of epoxy like JBWeld on an engine block is a far different case than on a header.  Headers can glow dull red under continuous load.  That's 900+* F.
This stuff might be a better choice.  It actually shows a header repair on the package, and claims 2400* F heat resistance.
http://www.autozone.com/autozone/accessories/CarGo-3-oz-ThermoSteel-High-Temp-metal-repair-jar/_/N-25y6?itemIdentifier=515553_0_0_
« Reply #5 on: September 22, 2013, 12:02:28 am »
yeah thats what i was afraid of. i would use the exhaust epoxy for sure.
Offline rich weyand
« Reply #6 on: September 22, 2013, 02:11:17 am »
I used "exhaust epoxy", not JBWeld, on my exhaust pipe, but it wasn't as high a temp as the CarGo stuff.
Offline pedigo78
  • Big Blue
« Reply #7 on: September 22, 2013, 12:29:00 pm »
great ill check it out. thinking about taking some over due leave. so ill be taking care of a few issues
Sgt Pedigo USMC
