Author Topic: 60's to 72 Rear Torque arm suspension in a 82 LWB?  (Read 5915 times)
Offline CanadianC10
« on: September 29, 2013, 05:05:34 pm »
sup fellas, thinking about savin a couple bucks and swapping in the torque arms from a 68 c10 I have down back, these are an ideal suspension with adding some strength to the arms themselves..
so someone tell me, has it been done before, as far as I know the frames are the same width behind the cab where the crossmember is..
1984 C10 LWB
CADDY 507
TH400
Frame twister
12.59 @ 108 .. 1.94 sixty
Offline Engineer
Re: 60's to 72 Rear Torque arm suspension in a 82 LWB?
« Reply #1 on: September 29, 2013, 06:55:51 pm »
What does it matter if it has been done before?
I say if you want to do it go for it. Let us know how it turns out.
If it hasn't been done before and you are the first people can look to you for the lead.
Do your homework, I think it will make a great project.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline CanadianC10
« Reply #2 on: September 29, 2013, 08:05:16 pm »
Yeah I'm gonna go for it just wanted to know if there was gonna to be problems with suspension travel
1984 C10 LWB
CADDY 507
TH400
Frame twister
Offline HAULIN IT
« Reply #3 on: September 29, 2013, 08:13:54 pm »
The area where the front crossmember would go is the same width, however the earlier truck frame with the arm/coil springs step inward about 3" shortly behind that area. This won't effect anything except if you are wanting to use the spring mounts, shock mounts, panhard bar & rear end housing from the early truck without ANY modifications. Going to coil-overs & a home-made (should be done anyway due to the shortness of the original) panhard bar should solve most of the hurdles. Lorne
Offline CanadianC10
« Reply #4 on: October 01, 2013, 04:05:07 pm »
Yeah I see what your saying, this truck is going to be a true hot rod, it has a big the biggest factory engine you'll find and a factory suspension chopped up, can't wait , doing the body work now
1984 C10 LWB
CADDY 507
TH400
Frame twister
« Reply #5 on: October 01, 2013, 07:12:36 pm »
I have seen I done a few times.  Porterbuilt and CPP make kits.  This is Porterbuilts http://www.porterbuiltfabrication.com/?p=409
CPP was in the latest custom trucks mag
captkaoscustoms.com
squarebody.biz
Offline CanadianC10
« Reply #6 on: October 04, 2013, 12:08:55 pm »
yeah im keeping it as stock as possible, and going to box the arms to make them more stable.. i want coil overs so i can adjust ride height
1984 C10 LWB
CADDY 507
TH400
Frame twister
