Author Topic: Window hard time rolling up and down  (Read 4829 times)
Offline darmentle
« on: October 02, 2013, 07:20:46 pm »
So in my 73 driver door it really stiff trying to roll the window up and down i have to guide the glass so it will close all the way. i got some PB blaster and and lubed everything and than i noticed that the window was not lining up in the felt track . is there a adjustment ?
Offline TwinStickPeterbilt
  • Diesel Enthusiast
Re: Window hard time rolling up and down
« Reply #1 on: October 02, 2013, 07:51:00 pm »
Sounds like to me it has gotten off track. If so you'll have to pull off the door panel to get to the window and set it back in the track. I could be completely wrong I'm coming from my semi truck back ground on this..
MY DREAM:
1978-79 Chevy K30 12V Cummins, NV4500, NP205 Twin Stick, 8'x8'x6" Flatbed.
Reality:
2002 Ford Ranger 4.0 automatic,4x4.
« Reply #2 on: October 02, 2013, 08:06:14 pm »
There is adjustment on the rear track.  It may need to be bent or loosened depending on the issue.
Make sure that the weatherstripping guides are in good order also.
Offline darmentle
« Reply #3 on: October 02, 2013, 08:26:33 pm »
sounds good i will check it out thanks .
