Author Topic: Problems  (Read 3007 times)
Offline darmentle
Problems
« on: October 05, 2013, 04:50:33 pm »
So i have some things i am trying to to fix on my 73. One is the gas gauge and the defrost. As for the gas gauge all my other gauges work but the gas . So i was trying to find the ground on the fuel tank but i cant see it do i need to pull the tank? or is the ground in a different spot?
The heater/defrost i turn it on and nothing i checked all the fuses everything is good. Is there something common that go out on these like a relay?
Offline square81
Re: Problems
« Reply #1 on: October 06, 2013, 01:15:57 pm »
Not sure with the heater and defrost not working. But what way is the gauge needle pointing, dual or single tank? If its at the 3 o'clock position is has a ground issue. The other way it may be the sender, gauge or the pink wire from the sender to the gauge.
Offline darmentle
Re: Problems
« Reply #2 on: October 06, 2013, 04:19:02 pm »
Gas gauge is currently pointed down in the 6o Clock position.
