Author Topic: carb model  (Read 18248 times)
Offline cwilson jr
carb model
« on: October 10, 2013, 07:50:20 pm »
i thought i started a post somewhat pertaining to this matter a long time ago and now i don't see it.
anyways, i have a q-jet with a casting number 17085226 and a date code of 2194 HLY.  i have deciphered this as being an 1985, 49-state emissions/chevy/auto and mfd. the 219th day of 84.  HLY plant?  idk this yet.
how do i figure out exactly which 4bbl i have?  i am trying to find a rebuilt replacement or i want to rebuild it myself and there seems to be several variables, or models such as:  2MC, 4M, 4MC, 4MV, M4MC, M4MV, E4MC, E4ME, not to mention the 4G and 4GC.  it also seems like someone used the orig carb. as the engine seems newer than the carb. i have? (see below)
i have an 85 K10 auto.  orig. had a 305, but a previous owner dropped in a goodwrench 350 and have the casting number as:
10066036
86-up
350
Car & Truck 2 & 4-bolt Passenger stick 1-piece seal
Offline Fairlane514
Re: carb model
« Reply #1 on: October 10, 2013, 08:29:51 pm »
As far as a rebuild kit for the carburetor you have listed, use the casting number 17085226 for the correct kit.
Offline cwilson jr
Re: carb model
« Reply #2 on: October 10, 2013, 09:57:27 pm »
after looking into some things, i doubt im going the rebuild route now.
what carb could i pick up that will work for me on my 350 listed below?
im looking for something with the best fuel economy as my main concern as well as something with the least emission equip.  i don't believe i even have anything left on my pickup as far as emission equip. goes.  there is even an egr delete plate on my manifold.  i do obviously have an electric choke.  is that something better to keep or would it be more reliable and not complicated to set up a manual choke?
Offline Fairlane514
Re: carb model
« Reply #3 on: October 10, 2013, 11:27:33 pm »
Easiest replacement would be a Qjet, everything will hook up easily and give you good fuel economy and performance. I would keep the electric choke as well. Where to buy is a good question, Sean Murphy Induction SMI has a good reputation, so I would start there.
Offline Pescados666
Re: carb model
« Reply #4 on: October 11, 2013, 12:16:35 am »
You have the same carb that just same off my suburban.  It's a R4-M4MED and it was only used for a year or so.
Quote
This carburetor was made by Rochester , The Rochester Products Division of General Motors was located in Rochester New York and built carburetors for GM vehicles since 1949 . It is a R4-M4MED the M4MED is a Electric side mounted choke with a Dual capacity solinoid Rochester Quadrajet 4 barrel carburetor, witch means the choke is located on the passenger side connected to the carburetor and uses key on power source and has a Dual capacity solinoid (normaly grey) .They started making them in 1985 and ran threw 1986. Most will have 1 inch 20 Fuel inlet . 1975 and up quadrajets use a different metering rod . This carburetor has a part number of  17085226 and used on 85-87 Chev/GMC/Truck BOP Grey Sol.
1985 Chevy C10 Suburban w/ 350 sbc and 700r4
Offline rich weyand
Re: carb model
« Reply #5 on: October 11, 2013, 01:14:54 am »
^^^  x2.  Sean will set you up.  And you will get better mileage from a properly set up Qjet than from either a Holley or Edelbrock.
Offline cwilson jr
Re: carb model
« Reply #6 on: October 11, 2013, 05:17:32 pm »
im going with a rebuilt q-jet.  i'm currently trying to find the simplest (no emission equip. at all) 4bbl with an electric choke.  i've located a couple and just have a couple of ?s.
1.  what is the difference between a q-jet that is compatible with an egr?  (mine has a delete plate, so i don't know where it connected to the carb originally and would like to know what the difference between the two are.  i easily see no-egr carbs when purchasing aftermarket, but i'm assuming you can't get a no-egr q-jet that would have an electric choke?)
2.  the rebuilt q-jets i'm looking at do not have an electronic component that my R4-M4MED has.  facing the vehicle with the hood open, the item in question is located on the top left-hand side of the carb.  i think this is something i want to do with out, but i  would like to know what it is.
3.  there is another electronic "solenoid?" on the lower right-hand side of the carb when looking with the hood open.
what i'm looking at:  http://www.ebay.com/itm/ROCHESTER-QUADRAJET-fits-1975-85-Chevy-cars-GMC-TRUCKS-w-Electric-choke-1191281-/190924523295?pt=Motors_Car_Truck_Parts_Accessories&hash=item2c73fd071f&vxp=mtr
« Last Edit: October 11, 2013, 05:49:00 pm by cwilson jr »
Offline rich weyand
Re: carb model
« Reply #7 on: October 11, 2013, 06:08:38 pm »
Bear in mind that Quadrajets have air bleeds and the like internally that GM tuned to the vehicle and engine by drilling them out to specific sizes.  Which is to say, Quadrajets are not all the same.  Going out and buying a "rebuilt q-jet" is not going to work out the way it should if it isn't vehicle specific.  Let's put it this way: If the seller does not ask you what vehicle you are putting it on, what the engine displacement is, what the intake manifold architecture is, what cam you have, what heads you have, and what exhaust system you have, you're getting ripped off.  They are treating the Quadrajet as if they were all the same, and they most definitely are not.
Go to SMI and have Sean set you up with one specifically for your vehicle.  You'll get much better performance and mileage both.
Offline cwilson jr
Re: carb model
« Reply #8 on: October 11, 2013, 08:27:03 pm »
thanks for the heads up.  i had already emailed sean and he said he was currently 7-8 weeks out.  i need something a lot sooner than that.  i have my original which works somewhat.  i believe there is something wrong with the choke and the carb itself is extremely dirty inside.
what would be my best route with my current carb?  a new choke?  easiest way to clean without rebuilding?
« Last Edit: October 11, 2013, 08:47:05 pm by cwilson jr »
Offline rich weyand
Re: carb model
« Reply #9 on: October 11, 2013, 09:11:53 pm »
You'll be dinking around trying to make a make-do carb function properly for three times that long, and there's no guarantee you'll even be close.
Here's what I would do:
- Order the carb from Sean.  Tell him what you got (stock base GM 350cid/260hp crate engine) and what manifold and exhaust system and all.
- Take the existing carb off.  Put it out on some newspapers covered with paper towels in the driveway and hose it down with carb cleaner.  Pay attention to bores and passages you can see, top and bottom.  Let it sit for a while and do it again.  Blow out all the passages you can and wipe it all off.
- Another option if you have access to an ultrasonic cleaner big enough to hold it is to drop it in there and let it buzz for a while.
- Measure the resistance of the choke coil to see if it is connected internally.  Shouldn't be zero, shouldn't be infinite.  Should be about 8.5 ohms.  If not, replace it.
- Put it all back on and limp around with whatever you get out of cleaning it until Sean's carb shows up.
Another thing you could do is rebuild yours.  You won't be changing any of the little drilled out tuning inserts, so the tune will stay right for the truck (assuming it's the right carb to start with, not always a warranted assumption on our truck given their age and how long there's been for someone to mess them up).  You also can't be sure you got everything cleaned out unless you are very meticulous about it.
But my advice, born of experience, is to take the long view.  The only thing that's more work and money than doing a long involved project on the truck, is doing a long involved project on the truck twice because you didn't do it right the first time.  Just do it right.  You'll be a lot happier when it's done.  Heck, it's only a couple months.
Offline Fairlane514
Re: carb model
« Reply #10 on: October 12, 2013, 12:25:56 am »
If you are in the Houston area, I can help you out.
Offline cwilson jr
Re: carb model
« Reply #11 on: October 12, 2013, 05:37:13 pm »
that stinks.  would of maybe traveled a little, but a little too far from PA.  thank you, sir anyways.
Offline farmerchris
Re: carb model
« Reply #12 on: October 13, 2013, 12:07:21 am »
you can try carbjunkys,www.carjunkys.com, phone#1-866-961-2272,i use them for my rebuild kits as they are ethanol compatible,they sell application specify carbs,as well kits and parts
its never finished
Offline cwilson jr
Re: carb model
« Reply #13 on: October 15, 2013, 12:21:11 pm »
was there a difference between 305 and 350 quadrajets?
after some detective work i think i may have finally figured out what's in my 85 K10 pickup and what was done years ago:
1) i know the truck came with a 305 stock and a 350 was later dropped in.
2) i ran the the numbers on the engine and they came back as:
86-up
350
3) the carb no. is:  17085226
(which looking at rebuild kits comes up with a match on an 85 305 truck.  does NOT match part numbers for an 85 350, NOR do they match an 86 350 or 305.)
SO, what it appears is someone removed the stock 305, dropped in a 86? 350 goodwrench crate and installed the original 305 q-jet on the new motor.  is this acceptable or do i need the correct q-jet to begin with?
Offline rich weyand
Re: carb model
« Reply #14 on: October 15, 2013, 01:22:54 pm »
I would think the air bleeds (little internal ports tuned by drilling an insert to spec) and such would be different.
If you call Sean at Sean Murphy Induction, he would know.  I called him on a carb question, and he told me I didn't need a new carb, what I needed to do is consider a new cam, so he's not going to be pushing for a sale if you are good to go where you are.
