Author Topic: Bypass and heater hoses  (Read 4963 times)
Offline Mike1973
« on: October 21, 2013, 08:25:28 am »
Although I believe the standard is 3/4" does anyone take issue with using 5/8" hose for the bypass on a BBC?  The reason I ask is this, I have a 45˚ fitting for the intake and a nice stainless 5/8" fitting for the pump.  Sure I can go grab 3/4" fittings but I have these already so I thought I'd put them to use.  Obviously less water flow but enough to make any difference?  My thought is no but anyone disagree?
Lastly, the 5/8" hose off the intake to the heater core is the feed line and the 3/4" hose to the radiator is the return right?
Offline raf2330
  • 73BigBlock
Re: Bypass and heater hoses
« Reply #1 on: October 21, 2013, 12:59:02 pm »
If I were going to be hauling anything with it I wouldn't do it. Just my 2 cents.
Working, & working, & working on 73 w/big block.
Offline Mike1973
« Reply #2 on: October 21, 2013, 03:25:00 pm »
I guess I was kind of under the impression that the bypass was really only there to allow coolant circulation until the thermostat opened up as to not induce hot spots in the heads.  That being said, the most this truck will haul is a yard of dirt from time to time.
Offline raf2330
  • 73BigBlock
« Reply #3 on: October 21, 2013, 04:46:42 pm »
Yea, your right about the bypass. I'm just one of those guys who has lived in or near the desert most of my life usually hauling a lot of weight and am always really nervous about cooling. It'll probably be fine. Like I said, just my 2 cents.
