Author Topic: My 77 K-5 build  (Read 84532 times)
Offline Displaced_Txn
Re: My 77 K-5 build
« Reply #30 on: April 05, 2014, 07:11:08 pm »
finally figured out why the high beams would come on when I applied the brakes, also got the new signal cam in and have signals now just no 4-ways. at first the high beams would flash with the left turn signal. but figured it was the relay for the classic industries hd headlight harness that was causing all the problems, pulled it out and now all is well. hoping I can get it inspected in the next few weeks before I go pick up my new car trailer.
Re: My 77 K-5 build
« Reply #31 on: April 06, 2014, 02:21:11 pm »
got a few more small things done to it to pass inspection. all thats left is licence plate bracket,plate light and geting the retcater welded back in for the seat belts.
Re: My 77 K-5 build
« Reply #32 on: April 06, 2014, 08:25:24 pm »
     Getting closer and closer.
Re: My 77 K-5 build
« Reply #33 on: April 09, 2014, 05:13:15 pm »
closer and closer till it gets loaded on a trailer and taken to texas.
Re: My 77 K-5 build
« Reply #34 on: April 19, 2014, 09:05:11 pm »
got it a new home
Re: My 77 K-5 build
« Reply #35 on: April 19, 2014, 10:21:08 pm »
      So now you have it in Texas with you ?   ;)
Re: My 77 K-5 build
« Reply #36 on: April 20, 2014, 06:47:47 am »
still in delaware. but will be moving back to texas in the next few weeks, plus trailer is long enough I can strap the factory wheels and tires down on the deck along with the k5
Re: My 77 K-5 build
« Reply #37 on: May 03, 2014, 09:26:55 pm »
Got the new  exhaust welded up today. 2.5 in pipes off the headers into the cherry bombs, and x pipe ( even though they ran it differently than normal)
and sorry for the crapp camera man on the cell phone video, but sounds alot better in person and got rid of the raspyness of the exhaust, cant wait to hear how it sounds with the cam.
https://www.youtube.com/watch?v=q1vMa9vq1Mc
https://www.youtube.com/watch?v=FxOVH3MnYlg
« Last Edit: May 03, 2014, 09:38:37 pm by Displaced_Txn »
Re: My 77 K-5 build
« Reply #38 on: May 03, 2014, 10:50:20 pm »
whats up with the yoke on the trans?
Re: My 77 K-5 build
« Reply #39 on: May 04, 2014, 09:27:24 am »
      It does look like it is pulled too far out, was your truck up on jack stands on the frame with the suspension drooped ?
Offline dvdswan
Re: My 77 K-5 build
« Reply #40 on: May 04, 2014, 12:13:36 pm »
looks like its been that way for a bit because of the rust.  don't brake hard or that may come out.
Re: My 77 K-5 build
« Reply #41 on: May 06, 2014, 11:10:31 pm »
or make any jumps
Re: My 77 K-5 build
« Reply #42 on: May 07, 2014, 06:47:30 pm »
its been that way ever since i put it in there, it came out of a newer k5 than mine. its only temporary untill it gets to texas where it will be gettng a sm465 with an np205 t-case in place of the th400 and np208
Re: My 77 K-5 build
« Reply #43 on: May 07, 2014, 07:47:46 pm »
     That is good news, I have seen what happens when a drive shaft falls out when in motion.  OUCH !
Re: My 77 K-5 build
« Reply #44 on: May 08, 2014, 09:42:43 pm »
I am been in a 70 Camaro with a built 454 running at a high rate of speed and drop the driveshaft.  At the time it happened we didn't know where the "flash" of light came from....
