Rear Drivelines, Drive Axles and Gearing
pinion angle noticeably off, but no vibration
Topic: pinion angle noticeably off, but no vibration (Read 11899 times)
shaved80
March 08, 2006, 09:17:00 pm »
you can tell by looking at it that the pinion angle is off, but i don't feel vibration at any speed. i should still shim it though right, as to not ruin the u joints?
roundedline
Re: pinion angle noticeably off, but no vibration
March 09, 2006, 12:07:00 pm »
I would probably shim it if it needs it. Typically you want about 3 or 4 degrees on a leaf setup. It should be nose down on the rearend side. You should be able to get an angle finder and place it on the rear yoke of the output shaft of rearend (take a reading) and then put it on the yoke of the output shaft and the should be the same.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
http://www.73-87chevytrucks.com
http://www.captkaoscustoms.com
