Author Topic: vacuum advance? again ?????  (Read 4203 times)
Offline darmentle
« on: November 05, 2013, 11:31:35 am »
I just noticed that the previous owner never hooked it up where is a good place to plug it into on the carb i have a holley truck avenger. i haven't had any performance issue with disconnected.
Part2
So i connected the vacuum advance and now when i drive between 1500-2000RPM i hear a strange KEk kek kek sound coming from what i think is the distributor. it only does it under load and  goes away a little after 2000Rpm. Thoughts ?
« Last Edit: November 07, 2013, 06:24:06 pm by darmentle »
Offline 81_Chevy
Re: vacuum advance?
« Reply #1 on: November 05, 2013, 11:47:32 am »
Try this: www.holley.com/data/Products/Technical/199R10268-4rev2.pdf‎
sorry if its a wrong link, cant open it on my school laptop. there should be an open port somewhere to connect it too.
Offline darmentle
Re: vacuum advance?
« Reply #2 on: November 05, 2013, 12:06:29 pm »
Thanks i see the little male fitting on the carb that says Timed Spark Vacuum Source Do i have to Check the timing after i hook that up .
Offline rich weyand
Re: vacuum advance?
« Reply #3 on: November 05, 2013, 12:16:32 pm »
No, you should always set ignition timing with the vacuum advance disconnected, then re-connect it.
Offline darmentle
Re: vacuum advance?
« Reply #4 on: November 05, 2013, 02:58:00 pm »
Thanks again
Offline darmentle
Re: vacuum advance?
« Reply #5 on: November 05, 2013, 04:08:25 pm »
oh i was gonna ask since we are talking distributors is there a difference in a normal HEI and MSD HEI i got the 6al box and wires just haven't got around to installing it . I was debating on getting the MSD  distributor is it worth the money
http://www.summitracing.com/parts/msd-8362/overview/
