Author Topic: HELP!! with a miss that I can't resolve!!  (Read 14412 times)
Re: HELP!! with a miss that I can't resolve!!
« Reply #15 on: November 07, 2013, 09:57:58 am »
Unless I missed it did you isolate the affected cylinder? Did you check the spark plugs?
Offline mattlwright
« Reply #16 on: November 07, 2013, 10:12:30 am »
All the plugs look the same, slight brown coloring on one side of the insulator. I've taken readings on the header tubes with a non-contact thermometer and they are all very close so it doesn't appear to be a single cylinder issue.
