Author Topic: Replacing seals  (Read 3984 times)
Offline peterb
  • 75 GMC Sierra Grande 15; 86 Custom Deluxe 10
    • autoliterate
Replacing seals
« on: November 07, 2013, 07:28:55 am »
I've a 1975 GMC Sierra Grande with a 350, auto trans. Original everything. Clean truck. Engine is pretty strong but major oil leakage from front seal. Is it worthwhile to replace the seals----or hold until I either replace engine or rebuild?.....i can't do the work myself so replace seals will cost $$ for labor I guess.......worth it on an old engine?
Re: Replacing seals
« Reply #1 on: November 07, 2013, 06:52:01 pm »
If it runs fine and has good pressure you can drop the pan and replace the front seal and reinstall it if you have a good confidence level.
Re: Replacing seals
« Reply #2 on: November 07, 2013, 11:42:32 pm »
i believe the question is, how much oil is "major"?
Offline peterb
    • autoliterate
Re: Replacing seals
« Reply #3 on: November 08, 2013, 02:41:19 pm »
Major oil leak--probably adding close to quart every 1 or 200 miles. I guess what I should do is check compression...and if that's good, count on the engine for a while, but put in new front seal? Is it true that I can put in a seal that's better than the original?
Re: Replacing seals
« Reply #4 on: November 08, 2013, 10:57:24 pm »
well since your original is leaking anything will be better ;)
