Author Topic: suspension  (Read 5864 times)
Offline mmartin6
suspension
« on: November 07, 2013, 10:57:58 am »
I have a 77 shortbed 2wd. I am rebuilding the front suspension with new ball joints from Moog and new upper and lower control arm bushings from Energy Suspension. I have run into a problem with the drivers side lower control arm. The ball joint fits very loosely, I was told that they have an oversized ball joint, but that didnt work because it came off. Does any one have or has come accross this problem? I cant find this part at any local auto parts store. If I go to a junkyard, not sure if I will get or run into the same problem. Any suggestions?
Re: suspension
« Reply #1 on: November 07, 2013, 06:49:32 pm »
I haven't ever had an issue with ball joints, have you found a solution?
Re: suspension
« Reply #2 on: November 07, 2013, 11:47:54 pm »
Offline mmartin6
Re: suspension
« Reply #3 on: November 08, 2013, 08:16:00 am »
I found another lower control arm from a partsonnet. Should be here in 5days, I did find an oversized ball joint but it still didnt work. i did notice that when i took the old one out it was spot welded in four places, guess who ever owned the truck before had that done. will post update as soon as i get other arm and when I get other side off.
