Author Topic: Lots to do, but where to start?  (Read 6791 times)
Offline Elpresidente
« on: November 08, 2013, 10:45:28 am »
Ok, so it's time to do some (more) serious restoration work on the 82 C10. on the list to be done:
-Remove the box
-Bead blast & paint the frame
-New heavy-half springs in the rear
-Regear to 3.73
-New box sides, reinstall the box
-Replace both rockers
-New front bushings/ball joints
-Find a way to make the truck sit 1" higher up front...(new coils?)
So my question in your experienced opinions is what's the best order to do all this in? it's a lot to do. Also I was going to paint something on the inside of the new box sides so they won't rust, something really durable that can handle daily use on & off pavement. Suggestions?
'82 Chev Scottsdale
Proud to be Canadian \m/
Offline 81_Chevy
Re: Lots to do, but where to start?
« Reply #1 on: November 08, 2013, 11:18:37 am »
IMO:
-Remove box
-Re-gear
-Heavy-half springs
-New front bushings/ ball joints
-Replace rockers
-Replace bedsides
-Bead blast and paint
-Reinstall box/ add undercoating
Fix mechanical first then cosmetic.
« Last Edit: November 08, 2013, 11:27:45 am by 81_Chevy »
Offline Engineer
« Reply #2 on: November 08, 2013, 04:54:18 pm »
I would do the mechanical stuff first, then the body work after.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline thirsty
    • Suitor's Garage
« Reply #3 on: November 08, 2013, 05:18:31 pm »
-New front bushings/ball joints. Make it ride and handle right and you will save money on tires and be safer.
-Find a way to make the truck sit 1" higher up front...(new coils?). Look for defects and do this as an upgrade later if no defects are found.
-Replace both rockers. Keep the cab from becoming the death of your truck.
-Bead blast & paint the frame. If rust is a serious issue get it done to preserve the frame. If not wait until you do box work.
-New box sides, reinstall the box. Look into another box. It might save you money and a lot of time.
-New heavy-half springs in the rear. Do this while the box is off.
-Regear to 3.73. Do this while the box is off also.
« Reply #4 on: November 08, 2013, 09:03:09 pm »
I should probably add, I already bought a pair of new bedsides second hand from a guy who never got the chance to use them. That was $500, where a good box up here would run me $1000+ even if it was shipped from the southern states.
'82 Chev Scottsdale
Offline Engineer
« Reply #5 on: November 09, 2013, 09:59:52 am »
Wow, I just bought a complete, clean rust free bed less tailgate for $150.00.
« Reply #6 on: November 15, 2013, 03:04:44 pm »
Rub it in. haha, but really up here people think that stuff like that is worth a fortune when it's really cheaper to just patch it up. Last summer someone was trying to sell a box off a '79 heavy-half for $1200, AND I could clearly see it needed bodywork behind the wheel well. Ridiculous! I only wish it was cheaper to ship something that big from Arizona or somewhere, winter beats the crap out of a vehicle.
« Last Edit: November 15, 2013, 03:12:18 pm by bd »
'82 Chev Scottsdale
Offline Engineer
« Reply #7 on: November 15, 2013, 09:24:02 pm »
I'm sure you can stumble onto a rust free long bed if you held out long enough.
Those army M-1008s that everybody was junking out a few years ago were mostly sought out by the rock crawlers, and mudders for the axles. The really low mileage bodies, and diesel engines were for the most part discarded.
« Reply #8 on: November 19, 2013, 01:22:43 pm »
Actually if I got my hands on one of those, i'd probably chop it to a short box and make it my full time off-road truck. There's not a lot of true M-1008's here in Canada, just clones.
'82 Chev Scottsdale
