Author Topic: meaty tires on c20 with 3/5 drop  (Read 5670 times)
Offline copperhead
« on: November 09, 2013, 02:59:17 am »
I'm dropping my truck 3/5 and want to stick some good sized meats in the back. I'm staying with 16's and hope to use stock size tires up front. Truck is a long bed stepside if that helps. She'll be run at the strip as build progresses. Never done a drop before any info on tire/wheel combos would be great thanks!
Re: meaty tires on c20 with 3/5 drop
« Reply #1 on: November 14, 2013, 10:54:23 pm »
you looking for width or height?
Offline copperhead
« Reply #2 on: November 17, 2013, 02:48:19 am »
Width I have 32x 8.5 right now. I would like to stay between 30 to 32 tall though.
« Reply #3 on: November 18, 2013, 01:42:28 pm »
For the rear you should be able to fit  one 14" wide with the right backspacing.
Offline copperhead
« Reply #4 on: November 19, 2013, 02:48:05 am »
Awesome thank you doesn't the c20 have 0 backspacing? I still have the old steelies on it( that will change)
« Reply #5 on: November 19, 2013, 11:33:45 pm »
Zero backspacing no, Offset probably not.
I think they were 4" backspacing.
