Author Topic: blower motor ?  (Read 5872 times)
Offline tigwelder
blower motor ?
« on: November 10, 2013, 08:33:02 pm »
1985 K 20 factory air. blower motor only works on high . had 3 speeds a month ago.any ideas?
Offline Jason S
Re: blower motor ?
« Reply #1 on: November 10, 2013, 09:05:24 pm »
Have you checked the connections at the resistor?
Offline tigwelder
Re: blower motor ?
« Reply #2 on: November 10, 2013, 09:36:30 pm »
No, where is it located? thanks
Offline Jason S
Re: blower motor ?
« Reply #3 on: November 11, 2013, 07:19:57 pm »
The resistor is located under the hood on the top side of the a/c evaporator housing.
Offline tigwelder
Re: blower motor ?
« Reply #4 on: November 12, 2013, 08:49:58 pm »
I WILL CHECK IT..
Offline Jason S
Re: blower motor ?
« Reply #5 on: November 12, 2013, 09:50:32 pm »
Also, you may want to move and slightly wiggle the fan blower speed switch between fan settings on the HVAC control.  The contacts within the switch may have a bit of corrosion, especially if the blower fan switch hasn't been operated in a while.
FYI- I had similar issues arise this morning...
