Author Topic: 77 K20 Project  (Read 12968 times)
Offline ChevyJoe
77 K20 Project
« on: November 13, 2013, 11:51:09 am »
1977 K20 with a 350 motor, has an Edelbrock intake and some aluminum valve covers, sounds pretty stock. $500 special from a few towns over, ran alright when I went to check it out, but it had been sitting for a few years after the guy lost the brakes plowing. Frame is extremely rusty with a few areas of holes/major rot. 7.5 foot hydraulic fisher plow works good, t-case shifter wouldn't move when I tried plowing last winter. A hammer and PB Blaster took care of that. It has the NP203 with Locking hubs up front. Almost done doing the brakes, should be done this weekend. Only the driver's side front was still attached to the proportioning valve.
This is a low budget, slow rebuild. Will never be a show truck, just going to drive it til the rear spring mount finally gives out or I find a replacement.
Just arrived home
The worst of the rust
Plow hooked up and working
More rust
83 C10 Stepside DD- 350/350, 10 Bolt GovLock
77 K20 Flatbed Plow truck- Slow, low budget project
Offline ChevyJoe
Re: 77 K20 Project
« Reply #1 on: November 13, 2013, 12:00:23 pm »
Bed is rotting more and more each day. Gotta watch where you step
Threw the belt the other day, new one goes on today
Even more rust. These are the old calipers
Old brake line frame fitting VS new
All cleaned up. (yes a lug is missing; there's 7 more right?)
Offline ChevyJoe
Re: 77 K20 Project
« Reply #2 on: November 14, 2013, 10:27:54 pm »
Air gun wouldn't take em off. Only broke 1 on the driver's side
While it's on jackstands decided to test fit some 33's I have
This is my "garage" floor
Offline ChevyJoe
Re: 77 K20 Project
« Reply #3 on: November 14, 2013, 10:32:23 pm »
One of the best parts on it
After searching the internet and tons of forums for the correct shift pattern of the 203, I found this under the seat  ::)
Offline ChevyJoe
Re: 77 K20 Project
« Reply #4 on: November 14, 2013, 10:32:51 pm »
I removed the rubber floor mat and insulation to get to the the center hump, and this is what was hiding
It's still solid, however the hump is not:
Offline werewolfx13
Re: 77 K20 Project
« Reply #5 on: November 15, 2013, 05:28:03 pm »
That is some serious cancer...Good luck, you've got fun times ahead of you.
Chris
'83 Chevy c10 Silverado SWB
Re: 77 K20 Project
« Reply #6 on: November 16, 2013, 06:15:23 am »
i would be scared of that thing. but 500 for a plow, engine, trans and axles aint a bad deal
Offline ChevyJoe
Re: 77 K20 Project
« Reply #7 on: November 17, 2013, 10:11:56 pm »
sure is, but it runs, moves, and the plow works so it wasn't too bad for it. I'll just keep fixing it til something really breaks on the frame and then it will be done
Ya, couldn't really beat it, plus the cab, doors and fenders are pretty good, only that 1 cab corner and passenger rocker are bad.
Offline ChevyJoe
Re: 77 K20 Project
« Reply #8 on: November 25, 2013, 10:14:05 am »
umm... that doesn't look right
figured out a way to hold up the hood since its bent
in the middle like they all do
Offline ehjorten
Re: 77 K20 Project
« Reply #9 on: November 25, 2013, 01:37:48 pm »
They don't bend in the middle if you lube the hinges.  Apparently any maintenance on this truck was not even an after thought.
-Erik-
Offline bluevan
  • Iron Hoarder
Re: 77 K20 Project
« Reply #10 on: November 25, 2013, 07:26:27 pm »
I have seen some rusty stuff up here in NH but... WOW
It looks like a rust monster got in that thing and laid eggs.  Then the babies hatched and ate their way out.
You did well though, as those fisher speedcast plow setuos sell for around $400 here if they are complete and working.  It will fit on all 73-87s and 88-91 blazer/sub/1tons.
- Joel
1982 GMC K10 (work in progress)
1989 Chevy G20 Van
1994 Chevy Impala SS
1974 Landcruiser (Chevy powered)
Offline ChevyJoe
Re: 77 K20 Project
« Reply #11 on: November 26, 2013, 04:18:47 pm »
Ya the guy I got it from used it as a plow truck for years til it lost the brakes and he just parked it. Has good tires tho!! ::)
Ya, its pretty bad. Really bad actually. But the whole running gear is good and the plow works awesome so it wasn't too bad of a deal. It'll probably be up for sale after winter
