Author Topic: frame swap??  (Read 3977 times)
Offline dale
frame swap??
« on: November 14, 2013, 06:32:34 pm »
will a 81/87 c10 cab fit on a 67/72 frame?
Re: frame swap??
« Reply #1 on: November 14, 2013, 08:02:04 pm »
Define fit?  It won't bolt up if that is what you are asking, and if you do get it on there, those have a shorter wheelbase.  You are going to have to fabricate mounts for everything...
Offline dale
Re: frame swap??
« Reply #2 on: November 14, 2013, 09:29:16 pm »
Just wondering if cab will fit on the frame, as far as cab mounts? Doing a front  and rear suspension swap.  I just need the frame from back cab Mount to core support...mines bent :(
Re: frame swap??
« Reply #3 on: November 14, 2013, 10:50:39 pm »
It won't bolt on.
