Author Topic: Review and pics: heated leather bucket seats  (Read 21940 times)
Offline rich weyand
« on: November 18, 2013, 02:56:39 pm »
I installed leather 40-20-40 buckets from discountvantruck.com, so here's some pics and a review.  They sell a bunch of different kinds, so this only applies to the 500 Series, and only to an install in a 1978 K-10.  Adjust accordingly.  Also, I have no connection with this outfit, just my opinion after putting these in my truck.
Quality: The seats and frame and all are built like a tank.  The leather is good quality and the sewing is superb.  The seats are all leather everywhere, not leather seating surfaces and vinyl elsewhere, or in the back, or where you can't see, etc.  It's all leather, period.  The foam and springing appears top-notch and is very comfortable.  Dimensions, features, look, etc. are all as per description and photos on the web site.
Riding position: The seating position ends up a couple inches higher and an inch or two closer to the wheel.  When I put the seat back more vertical than stock (which is better for my back problems), what I saw centered in the unadjusted rear-view mirror was the inside of the tailgate.  Some of that rise is the seat height and some is the seat back being more vertical.  Also, the springs and foam in the new seats are new, and the old seat, while reconditioned, was probably lower than stock from sag.
Ordering and delivery:  Linda was easy to work with.  I wanted a brighter red than their stock colors to better match the stock interior, and she offered further samples.  The stock color was more burgundy and looked brown next to the stock interior.  The red sample she sent after talking it over with her is a better match.  (It looks orange in the flash, but it's bright red.)  Delivery was "three to four weeks"; it actually shipped four and a half weeks after order, and took a week to get here.  Thanksgiving intervened, however, and they shipped 20 business days after order.  The order was filled correctly, with the right colors in the right places, heaters and lumbar supports included as per order, the correct brackets, etc.
Instructions:  Instructions are rudimentary but sufficient.  The instructions said to mount seats, console and brackets to the frame and put the whole thing in as an assembly.  That looked pretty difficult, as the whole setup is larger and bulkier than the stock seat.  We put the frame in the truck, then put the brackets on and left the bolts loose, then mounted the console (take the little tray out to get at the mounting bolts), then mounted the seats, then got the floor bolts started, then tightened the brackets up.  To mount the seats on the frame inside the truck, we put a small piece of 4x4 under the frame to hold the whole thing up so we could get access to the hardware underneath.
Overall value:  At under $1500 delivered for this setup, it's a tremendous value compared to what else is out there.
Fitment and tweaks: If you just put everything together as they say to, it will work fine, but there are some tweaks.  The brackets for the 73-87 Chevys has a weld seam on the inside of the angle that holds the frame away from the bracket about 3/16".  Now, the brackets end up in the right place to bolt into the floor, but I didn't like that gap, so I put washers in to fill it so I could torque them down without distorting the frame or bracket.
The seating position is a little close to the wheel, and at the same time the seat didn't go all the way back -- it hit end-of-track.  Also, the seat of the jump seat was far enough forward that the transfer case shift lever on the modded NP203 was just against the jump seat in 4HI.  We drilled two new holes in each bracket 1-3/4" behind the existing holes, which moved the whole seat assembly back 1-3/4".  This allowed the seat to go back all the way until it hit the rise in the floor behind the seats, and still had plenty of adjustment forward, and also gave me a 1-3/4" gap to the transfer case lever.
The headrests would only go down half way before they seized up, but each of the mounting rods individually went all the way down easily.  A bit of measurement showed that the rods were 0.090" further apart than the holes.  I put a couple of blocks between the rods and then cinched down across the rods right up against the headrest with a pony clamp until they were correctly spaced.
There is a latch release for the jump seat back.  The release lever was pressed into the drivers seat bolster and it had a tab on it that dug pretty deep.  I removed the jump seat back latch and release lever, as I won't be driving around with the jump seat open unless there is someone sitting in it.
We also added washers to the seat mounting bolts where they went through slots, and replaced the provided nuts, which have the locking teeth on the bottom, with stainless steel nylon-insert locking nuts.
So, basically, we did a bit of tweaking, which I think is well within the capabilities of most people on the forum, and there were no major gotchas, missing parts, re-machining or fabricating or anything serious like that.
On to the pics!
Stock seat:
What you get.  Frame, brackets, seats, center console/jumpseat, headrests.
Test-fitting the frame and brackets:
Bracket modification.  We drilled two new holes 1-3/4" behind the existing holes.
Installed, console down:
Installed, jumpseat open:
Console storage compartment:
Jump seat storage compartment (without flash, you can tell the color better):
Close up of the leather and stitching detail.  The quality is very good:
« Last Edit: November 01, 2014, 10:35:43 pm by rich weyand »
Offline darmentle
Re: Review and pics: heated leather bucket seats
« Reply #1 on: November 18, 2013, 04:14:14 pm »
Looks nice jealous over the center console be nice to have one.
Offline rich weyand
« Reply #2 on: November 18, 2013, 04:34:49 pm »
Sitting center on this is actually more comfortable than on the stock bench.  It has a little more lateral support,  in the seat shape and in sitting between the seat backs of the buckets.
Big deal for getting this was I wanted headrests, so I wouldn't punch out the window with my head if I got rear-ended.  Bonuses: leather wears much better than cloth; seat heaters are very nice (particularly with leather); buckets and console setup; I got to tone down the amount of red in the cab.
« Reply #3 on: November 18, 2013, 04:39:17 pm »
Looks great!!!
Offline achevy1978
« Reply #4 on: December 29, 2013, 08:57:22 pm »
what you do with the one you took out
Offline rich weyand
« Reply #5 on: December 30, 2013, 12:28:04 am »
I gave it to a fellow here in Indiana who was trying to fix up his truck on a shoestring budget.
Offline dvdswan
« Reply #6 on: December 30, 2013, 10:14:10 am »
sweet looking seats.  love the console too.  so do both seats adjust or just the driver?
Offline rich weyand
« Reply #7 on: December 30, 2013, 11:19:03 am »
Both seats adjust fore-and-aft, recline, and lumbar support.  Separate seat heater controls as well.
