Author Topic: lower control arms  (Read 4722 times)
Offline lokmotion85
lower control arms
« on: April 28, 2006, 08:56:00 am »
ok finally I have a question for ya all, is there a physical difference in the lower control arms from a 3/4 ton & a 1 ton , the 1 ton lookes " longer" going to change all to 3/4 just what to know if any diff , I'm missing the drivers side on the 78 c-30 frame I'm using ,any info will be appreciated, .. Toby
Offline roundedline
Re: lower control arms
« Reply #1 on: April 28, 2006, 11:18:00 am »
Been a LONG time since I have even looked at a 1Ton, but It should be the same.  Can you lay them side by side?
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline lokmotion85
« Reply #2 on: April 28, 2006, 06:39:00 pm »
thats what I'm going to do as soon as I get the 1-ton off , I was seeing if anyone knew before i tore it down , hate to get rid of something if I can use it , I bent one on my 1/2 ton 85 a few yrs ago , could"nt find one , bought some tubular ones , I was thinking they were the same , but like you , been a while since I messed w/ a 1-ton ,thanks for response..Toby
