Author Topic: 87 pickup speakers  (Read 15722 times)
Offline dc7432
87 pickup speakers
« on: November 21, 2013, 04:48:42 pm »
What did the typical stock truck have for speakers. I was told two 4x10s in the back cab corners with three under the dash? I believe there's two 3.5 with a 6x9 upfront in the middle is that correct. Has anyone installed three in the front thanks. Any recommendation on number of speakers
Re: 87 pickup speakers
« Reply #1 on: November 21, 2013, 05:28:40 pm »
OE stereos employed two 4x10s in the cab corners behind the seat and two 3.5s in the top of the dash in front of the driver and passenger.  OE monophonics employed a single 6x9 4x10 in the top center of the dash.
As for recommendations, it depends on how you like your music to sound, how much you're willing to spend and/or how much effort you're willing to invest.  Four locations for mids/tweeters (two front, two rear) and one or two subs behind the seat seem to be the most popular combos and deliver the best sound overall.  Searching "stereo" and "speakers" on this site should provide hours of reading material.  Sound systems are a hot topic.
« Last Edit: November 21, 2013, 07:42:23 pm by bd »
« Reply #2 on: November 21, 2013, 06:10:06 pm »
On my 1985 the center speaker is a 4x10 for the mono AM factory radio
« Reply #3 on: November 21, 2013, 07:20:16 pm »
Never saw one with a 6x9 in the dash all of them were 4x10's
« Reply #4 on: November 21, 2013, 07:32:13 pm »
You're both right!  Don't know what I was thinking.  4x10 was the factory size in the center dash.
Offline rich weyand
« Reply #5 on: November 21, 2013, 08:52:03 pm »
I have a Highliner headliner with 4 Kicker DS400s in it, and a Lanzar powered subwoofer between the seats.  See adjacent thread.
I like this setup a lot, and it was pretty easy, with no mods to the interior of the truck.
Offline 81_Chevy
« Reply #6 on: November 22, 2013, 08:48:55 am »
ive got two 12inch subs behind my back seat, two 6x9's in the cab corners, and DUAL voice coil 4x10 in the center that branches out on each side to 3 inch tweeters. sounds amazing.
Offline Edemich
« Reply #7 on: March 23, 2014, 04:05:49 pm »
Rich,
Did you modify the high liner for the 4 kickers or is that what it cam with?
Dark Ming Blue 85' K10 w/355 SBC, Edelbrock top end kit with Scorpion Roller Rockers, 2001 14B FF w/4.56 gears, NV4500 5spd, One Piece Rear and Door Glass
« Reply #8 on: March 24, 2014, 06:35:28 am »
Rich,
     They came like that, see highliner headliner webpage here.
Offline rich weyand
« Reply #9 on: March 24, 2014, 08:07:45 am »
Rich,
Did you modify the high liner for the 4 kickers or is that what it came with?
Neither.  It came with crappy speakers, which mounted from behind.  I removed them with extreme prejudice, cutting the baskets up with tin snips and pulling the pieces though the holes.  I then mounted Kicker DS-400s from the front using U-type speed nuts.  No modifications required.
« Reply #10 on: March 24, 2014, 12:10:29 pm »
actually my 79 center speaker hole was smaller than my 80s idk why but had to do some fab work to make them the same size. it was about 1" smaller
Offline Edemich
« Reply #11 on: March 24, 2014, 01:30:09 pm »
Rich I sent you a message
