Author Topic: Steel dash removal questions  (Read 3643 times)
Offline bill.ohlhausen.7
« on: November 23, 2013, 12:04:23 am »
when you install the dash did you put any type of sealant or ??? ? at the lip were it was spot welded?
what did you use to drill out the spot welds?
« Last Edit: November 24, 2013, 10:53:25 am by Captkaos »
Re: Steel dash removal questions
« Reply #1 on: November 24, 2013, 10:54:21 am »
You can use a spotweld drill or a regular drill to remove the spot welds.  If you don't destroy the original lip sealant isn't required.
