Author Topic: Project 87 Short Step  (Read 105379 times)
Offline hobbz
Re: Project 87 Short Step
« Reply #105 on: May 16, 2015, 01:28:52 pm »
I am impressed with the before and after! I would go maybe an inch lower in the front and no more.
Thanks.  I think I am going to drive it like this some and see if the front end settles any.
I ordered new bushings for the cab. They will be here Monday and hopefully I will have time to get them in.
I still need a windshield and need to install my locker before I start driving it.
1987 Chevy R10 Short/Step -  350/th350
Build Thread
Offline hobbz
« Reply #106 on: May 21, 2015, 02:44:54 pm »
Changed my cab mount bushings and installed my locker today.
Build Thread
Offline FlatBlack77
« Reply #107 on: May 22, 2015, 08:39:26 pm »
how did the bushings go? i need to do the same thing on my 77
Offline hobbz
« Reply #108 on: May 22, 2015, 09:48:35 pm »
Had to use breaker bar to break the bolts loose. After that the impact took them the rest of the way out.  Did both on each side at a time.
Build Thread
Offline FlatBlack77
« Reply #109 on: May 23, 2015, 06:49:18 am »
did you get Energy Suspension? or another brand
Offline hobbz
« Reply #110 on: May 23, 2015, 08:10:13 am »
I went back with stock replacement
Build Thread
Offline FlatBlack77
« Reply #111 on: May 23, 2015, 11:46:55 am »
thanks dude keep the progress coiming!
Offline hobbz
« Reply #112 on: May 23, 2015, 09:42:04 pm »
Picked up some spinner center caps yesterday at the Springfield Ohio swap meet.
Build Thread
Offline hobbz
« Reply #113 on: May 30, 2015, 04:14:54 pm »
I printed some adapters so I could use 3 3/8 gauges instead of enlarging the hole for 5" gauges.
Build Thread
Offline Cane
« Reply #114 on: May 30, 2015, 06:46:54 pm »
Real nice truck, hobbz, I just read all of your journey.... I have tons of questions on the wiring... What kit did you get and where? Did you just tear out and start new? Timeline for all? Thanks man and keep it up!
Offline hobbz
« Reply #115 on: May 30, 2015, 08:21:19 pm »
I bought the wire harness from ebay, just search hot rod wiring harness...
Yes, I tore every single factory wire out of the truck and started fresh, including new headlight and parking light sockets.
I have been working on the truck for about a year and a half just as a project.  Probably could have been to the point I am now in just a few months if you worked on it every day after work.
« Last Edit: May 30, 2015, 08:47:35 pm by bd »
Build Thread
Offline Cane
« Reply #116 on: May 30, 2015, 08:27:49 pm »
What was your timeline from start to finish on the wiring? seems like you did it in about 2 days...any diagrams that helped you? TIA!
Offline hobbz
« Reply #117 on: May 30, 2015, 09:06:31 pm »
I was able to get it wired enough to start in a day or 2. Lights and stuff I just did as I got time later on.
Make sure you have a gm column wiring diagram
Build Thread
