Author Topic: Spark plugs arcing  (Read 4919 times)
Offline winningz
Spark plugs arcing
« on: November 25, 2013, 11:56:29 pm »
My spark plug in the back is arcing to my header.  ??? its the fourth one closest to the cab on the driver side. 1978 chevy k10
Online bd
Re: Spark plugs arcing
« Reply #1 on: November 26, 2013, 12:46:15 am »
Is there a question there somewhere?   ???
On the left (driver's) side of the engine the cylinders are numbered front-to-rear, 1-3-5-7; and on the right (passenger's) side front-to-rear, 2-4-6-8.  So, you're telling us the #7 spark plug wire is arcing to the exhaust.
How much clearance (in inches) do you see between the wire and the header?  Post a pic.
Offline winningz
« Reply #2 on: November 26, 2013, 12:54:33 am »
ha sorry got all worked up. theres zero clearance, it is touching the header. cant get the dang thing off now its stuck to the header. will post a pic brb
Offline winningz
« Reply #3 on: November 26, 2013, 01:00:29 am »
Here is the pic. It is touching the header and I can't get it off now
Sent from my DROID RAZR using Tapatalk
Online bd
« Reply #4 on: November 26, 2013, 03:28:19 am »
You need to dimple the header pipe to produce an air gap between the wire and the pipe.  Try to find a shorter "header" spark plug - Accel markets them.  Replace the damaged spark plug wire.  Sparingly smear some dialectric grease inside the spark plug boot before connecting it to the plug.  Pick up and install Nomex spark plug sleeves on the business ends of the plug wires.  Be careful when removing the wires in the future, so as not to tear the boots.
