Author Topic: 1975 Blazer top cover rear door  (Read 14867 times)
Offline mpierce9
« on: November 28, 2013, 07:52:46 am »
Hey guys, I've been looking around and I'm either typing the wrong thing in the search boxes or the information isn't available.
I have recently purchased a 1975 Blazer. The top cover is missing the rear gate. I'm wondering where i could find a replacement.
Will any rear door fit?
Does a specific year fit better than others?
Is there another alternative I'm not considering?
Re: 1975 Blazer top cover rear door
« Reply #1 on: November 28, 2013, 08:23:19 am »
I am no Blazer expert but it appears you have a pickup tailgate.  I thought they all had windows that rolled up into a channel in the fiberglass top...
Offline mpierce9
« Reply #2 on: November 28, 2013, 10:43:51 am »
Thank you. I believe you are exactly correct. For some reason i was thinking it would be similar to a camper top where the glass attached to the top. I will start looking for a rear door for this. Thanks again.
« Reply #3 on: December 02, 2013, 10:26:57 am »
You need the actual Blazer tailgate.  The normal pickup tailgate was an option on the Blazers but I have never seen one with it..
Offline dvdswan
« Reply #4 on: December 18, 2013, 12:49:35 pm »
as Captkaos said, it needs to be a Blazer tailgate.  a suburban tailgate won't work either, the glass is different between the two as well as the gate.  blazer had the removeable top and the suburban did not so the back window and run channel are different.
Offline ZUKE75
« Reply #5 on: June 15, 2016, 05:40:00 pm »
A lot of people swap the tail gate to the pick up tail gate if the mainly use a soft top. It was an option for non hard top from the factory with a pick up tai lgate
