Author Topic: Muncie SM465  (Read 7891 times)
Offline jasong
Muncie SM465
« on: November 30, 2013, 06:36:37 pm »
Ok you muncie guys, so here is my trouble, while elk hunting, I backed up my truck (1989 V3500 4X4, 454 tbi, muncie sm465 with 205 transfer case) and parked while I glassed the hill side. I then headed up the road a ways, I did not notice anything wrong at that time but when I got going and tried to shift into third gear, it would not go.  >:(  I then found that I had no third, fourth, or reverse, first and second still worked just fine.
I limped the truck home and got the tranny tore out and apart, everything with the exception of third gear looks brand new. Third gear is worn down a bit from being ground while still moving forward apparently, this truck was a construction rig before I purchased it. I cannot find anything that looks to have caused this, I was going to rebuild it however I don't know what needs to be replaced and I don't want to rebuild it and find that was not the problem. I have talked to several of the local mechanics and they don't seem to know what might be wrong or just don't care, Any help or suggestions would be greatly appreciated.  :-\
Offline Engineer
Re: Muncie SM465
« Reply #1 on: December 01, 2013, 01:57:01 pm »
Those transmissions are almost bullet proof. But they are not indestructible. It sounds like the previous owners abused it by shifting without the clutch.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Re: Muncie SM465
« Reply #2 on: December 02, 2013, 10:04:32 am »
Ditto on the above.
