Author Topic: HOW CAN I GET MORE ROOM IN THE CAB ???  (Read 17875 times)
Offline bigpetie
« on: December 02, 2013, 02:04:36 pm »
I'm 6'4 300 plus... Any[ seat mods??? I do not have  tilt... I have a smaller steering wheels
78 GMC HI-SIERRA S/B
79 CHEVY BONANZA
79 LS1 MALIBU
Offline 454Man
  • Why Race?
Re: HOW CAN I GET MORE ROOM IN THE CAB ???
« Reply #1 on: December 02, 2013, 02:50:07 pm »
Tilt well make a world of a diff. I miss mine so... IM 6ft 2in with a bench seat all the way back tilt was the best thing that happened to my truck
« Reply #2 on: December 02, 2013, 03:56:57 pm »
You didn't mention the year of your truck but the 1985 and newer seats have thinner backs to them.
Offline bigpetie
« Reply #3 on: December 02, 2013, 05:30:31 pm »
Its a 78..will they bolt right in ?
79 CHEVY BONANZA
79 LS1 MALIBU
« Reply #4 on: December 02, 2013, 06:14:14 pm »
Yes the seats are a direct bolt in.  The most room I have had was from a 91 Suburban front seat.  Granted it didn't tilt forward but it sure made it the roomiest of all.  It was paired with a tilt wheel column and a 76 Camaro steering wheel
Offline blazing816
« Reply #5 on: December 03, 2013, 03:19:16 pm »
im 6'2" and I have a 86 bench seat and got myself a tilt column and It works out great for me and I still have stock wheel.
Offline nlauffer
« Reply #6 on: December 03, 2013, 04:37:30 pm »
One thing to look at is your steering wheel.  I had a small foam grip one once.  It had a deeper dish than the stock and then factor in the thickness of the adapter.  It put the wheel to close for me and I'm only 5'9".  Might want to look into a wheel with little to no dish.
Offline bigpetie
« Reply #7 on: December 03, 2013, 07:01:15 pm »
PROBLEM SOLVED !  ;D..i took out the studs on b..oth sides of the seat bottom that the top latches to..now the back rest will lay back about 2-3" against the cab...
79 CHEVY BONANZA
79 LS1 MALIBU
Offline 454Man
  • Why Race?
« Reply #8 on: December 03, 2013, 08:22:12 pm »
pics please
« Reply #9 on: December 03, 2013, 08:34:47 pm »
If your seat back wasn't against the back of the cab without the seat modification you made, your seat tracks were not back all the way.  It is a common problem if the PO did not have it all the way back.  When I pick up a used truck I always take the seat out to clean and adjust the tracks.  I also have found a lot of money over the years...
Offline bigpetie
« Reply #10 on: December 03, 2013, 09:11:27 pm »
the seat was back far as I could get it to go....
79 CHEVY BONANZA
79 LS1 MALIBU
Offline bigpetie
« Reply #11 on: December 03, 2013, 09:14:29 pm »
if I had a tIlt column that would be even better... I have a new steering wheel with less dish coming tomorrow..
79 CHEVY BONANZA
79 LS1 MALIBU
Offline bigpetie
« Reply #12 on: December 04, 2013, 06:19:38 pm »
NEW WHEEL WITH 2" DISH...
79 CHEVY BONANZA
79 LS1 MALIBU
Offline Thumper
« Reply #13 on: December 29, 2013, 05:53:20 pm »
 I was able to gain a little room by loosening the 4 main bolts that hold the steering column
and sliding the column forward. There are 2 nuts under the dash and 2 nuts on a bracket
under the brake booster on the firewall, loosen all 4 of these, then sit behind the wheel
and "bump" the wheel forward with both hands. This has gained me an inch or two on my
trucks.
1990 K5 4speed
1984 k10 long bed 4" lift
1985 K5 2.5" lift
2013 Camaro
1987 Monte SS 454
Offline bigpetie
« Reply #14 on: December 30, 2013, 01:15:12 pm »
trucks.
thanks i'll try that..
79 CHEVY BONANZA
79 LS1 MALIBU
