Author Topic: 454 Marine engine?  (Read 3693 times)
Offline sgreen3
454 Marine engine?
« on: December 06, 2013, 11:47:48 am »
Hey fellas, in my attempt to find a big block for my truck. I cam across a friend that has a early 90s 454 marine engine (no place to mount mechanical fuel pump on the block). Its been taken out of the boat an has been tore down. An has had the crack turned an the block machined with new cam bearings an freeze plugs installed. My question is, would this make a good donor engine for my truck, or should I stay away from it since it was a "marine" engine? Thanks fellas!
Offline Engineer
Re: 454 Marine engine?
« Reply #1 on: December 06, 2013, 12:55:29 pm »
Should make a fine foundation for a big block build. It should be a 4-bolt main block. :)
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
